RedBassett 0 Posted November 16, 2016 I have inserted some Elation Platinum Spot 15R Pros into my lighting plot. They render just fine on the plot and in 3D, however when I switch a sheet layer with a viewport of the plot, they do not show. In fact, colour scrollers and other accessories aren't showing either in viewports. The symbol is being recognized, as I can hover over a dotted circular outline where it should be, but nothing is showing: What might be causing this? Quote Share this post Link to post
JBenghiat 333 Posted November 16, 2016 Have you checked your class visibilities in your viewports? Those symbols can be in a class that is hidden. -Josh Quote Share this post Link to post
RedBassett 0 Posted November 16, 2016 5 minutes ago, JBenghiat said: Have you checked your class visibilities in your viewports? Those symbols can be in a class that is hidden. -Josh The 15R symbols and scroller symbols are in the same class (None) and layer as the source four symbols that render correctly. Quote Share this post Link to post
Taproot 237 Posted November 16, 2016 It may be that the container class is "none", but the objects making up the symbol are probably in another class that is hidden in your viewports. Try editing the symbol and see what classes the objects are on - then turn those classes on in your viewport visibility. 1 Quote Share this post Link to post
corbinhand 3 Posted November 16, 2016 Also check the "Dimension" class. I've run into this issue with several of the Elation symbols. Id suggest editing the classes within each of the symbols you use most frequently. Quote Share this post Link to post
RedBassett 0 Posted November 17, 2016 22 hours ago, Taproot said: It may be that the container class is "none", but the objects making up the symbol are probably in another class that is hidden in your viewports. Try editing the symbol and see what classes the objects are on - then turn those classes on in your viewport visibility. Yup, it was classes used inside the symbol causing the issue. Thanks! 22 hours ago, corbinhand said: Also check the "Dimension" class. I've run into this issue with several of the Elation symbols. Id suggest editing the classes within each of the symbols you use most frequently. While this class was already on, this is a good check as well. Thanks! Quote Share this post Link to post
Arky 2 Posted August 15, 2018 On 11/15/2016 at 5:06 PM, Taproot said: It may be that the container class is "none", but the objects making up the symbol are probably in another class that is hidden in your viewports. Try editing the symbol and see what classes the objects are on - then turn those classes on in your viewport visibility. This solved my issue, very grateful. Quote Share this post Link to post
scottmoore 317 Posted August 16, 2018 Glad that solved the problem. I should note that there are times that spotlight fixtures disappear for no good reason. “Refresh Instruments” ( command / ) will solve this. It’s a little frustrating when that happens. Quote Share this post Link to post
