Marionette - Nurbs Curve
gonzalezj
Hello,
How does the Nurbs Curve node work in Marionette? I currently have an ordered list plugged in, a Bool to make the Nurbs Curve tool false so that it interpolates between the provided points, and a Real node with the value of 3 for the curves degrees. When i run the script I get an error with the Nurbs Curve node. Are these the incorrect inputs? Any recommendations welcome.
Thanks!
10 answers to this question
  • Marionette Maven
2 minutes ago, gonzalezj said:
Hello,
Thanks!
Can you provide a file, if not, could you provide a screenshot of your error message?
Thanks!
  • Marionette Maven
Alright, so at a first glance, the most glaring issue I'm seeing is that you're using "Point2" nodes instead of "Point3".
I can work on getting a change in where that won't matter later on, but for now try using Point3 nodes with your Z set to zero (assuming that's what you want), and let me know if that works any better.
