Carles Olle
Invoke custom tool from menu command
Hi,
I need some help with custom plug-ins.
I created a custom plug-in with a custom point object. It seems to work fine
Now I need to create a command that will be executed from a menu that invokes the tool to place the custom point object in the document.
I've been looking around but I don't seem to find how to do it.
My questions are
  1. How to invoke the tool for the custom point object from the command script
  2. How to set up the parameters for the custom tool (Height, Width, etc.) for the new object I'm about to create
Thanks in advance.
You don't need to invoke your tool to place it with a script. Since you coded the object, you know everything about it. Simply PLACE the object, ATTACH the PIO record to it, and FILL in all the record fields with values you want.
Here's a VS sample of a bolt object (not a custom object, but the steps are the same).
H := CreateCustomObject('Hex Bolt (ISO)', 0, 0.8, #0d);
Record(H, 'Hex Bolt (ISO)');
Field(H, 'Hex Bolt (ISO)', 'boltType', 'Hex Bolt');
Field(H, 'Hex Bolt (ISO)', 'size_1', 'M12 X 1,75');
Field(H, 'Hex Bolt (ISO)', '__size_2', 'M12 x 1,75');
Field(H, 'Hex Bolt (ISO)', '__size_3', 'M12 x 1,75');
Field(H, 'Hex Bolt (ISO)', '__size_4', 'M12 x 1,75');
Field(H, 'Hex Bolt (ISO)', 'length', '1.9685');
Field(H, 'Hex Bolt (ISO)', 'threadStyle', 'Simplified');
Field(H, 'Hex Bolt (ISO)', 'view', 'Front');
Field(H, 'Hex Bolt (ISO)', 'drawFillet', 'False');
Field(H, 'Hex Bolt (ISO)', 'stdLength', 'True');
Field(H, 'Hex Bolt (ISO)', 'centerline', 'False');
Field(H, 'Hex Bolt (ISO)', '__oldSize', 'M12 X 1,75');
Field(H, 'Hex Bolt (ISO)', '__oldType', '1');
If that is not enough, then ResetObject(H) when you're done.
It should be pretty easy to Pythonize this.
HTH,
Raymond
