Confirmed, the intensity of the displacement mapping is being affected by the size of the plane it is mapped to. this should not be the case. I will post if there are any updates.
This example image shows the intersection of 4 rectangular 3d polygons, all with the same texture and mapping settings, the only difference being the size of the 3d polys. As you can see, the displacement become less intense on the larger ones.
martinfdc
@JimW
Do you know if this bug regarding the 'intensity of displacement mapping relative to applied object size' has been fixed in VW2017 SP1?
I'm having trouble with the amount of displacement mapping (for my grass texture) being displayed in the different planes of my site model.
Thanks in advance
p.s.: I attach a screenshot that explains the issue.
the problem intensifies when there is a curve in the geometry (see image below):
Edited by martinfdcLink to comment
17 answers to this question
