7 answers to this question
I attach the file as requested.
The problem is that there are trees made as image prop that are no more visibile in Open GL render mode. They were ok with the first release of vw2017 but not with the sp1. If I copy and paste them in a new file they work again. The same happens opening the file on a computer having the first release vw 2017. May be I have to copy and paste all the drawing in a new empty file.
ROP_161008_RENDERFILE_sh.vwx.zip
To copy and paste all the drawing into a new empty file does'nt work, but I have seen the trees right beside the drawing like having a offset. If I zoom toward the new position of the trees nothing is visible. Anyway if I click a tree in the right position inside the drawing I can see the orange fence and the info palette confirms the selection: but the tree is not visible in Open GL render mode.
2 hours ago, Pierluigi Feltri said:
After upgrading to vw2017 sp1 image props are no longer visible in Open GL render mode.
Could you help me?
You are right.
I tried VW Ressource Silhouettes, I can't see them in OpenGL.
Switch off "Use Textures" in OpenGL.
This way you can at least see where they are :D
Could you help me?
I think that was corrected again in SP2 (?)
At least I can se Ozbreed IP's in my OpenGL.
Edited by zoomer
1 hour ago, Pierluigi Feltri said:
It doesn't work neither in the sp2 release. It should be fixed.
Do you have an example from one of the standard VW Libraries that I can check ?
