knickers Posted October 31, 2016 Share Posted October 31, 2016 Hi there, I have put together a drawing and want the worksheet to count nested symbols in a specific area of the drawing. I have named a rectangle area in the drawing "000-OrderArea", and they Symbol "ProjectSeat" appears in this area both on its own, as well as being nested within two other symbols. Here is the formula in the Worksheet cell: =COUNT((INSYMBOL & (S='ProjectSeat') & (LOC='000-OrderArea'))) The Worksheet is only counting the 'loose' symbols in the area, not any of the nested ones. Any clues as to how I can get it to count ALL of the symbols in the area? Cheers, Nick Quote Link to comment
Pat Stanford Posted November 1, 2016 Share Posted November 1, 2016 The same topic was discussed in December of 2014. I don't think a viable solution was ever found. Sorry. Quote Link to comment
knickers Posted November 1, 2016 Author Share Posted November 1, 2016 Thanks for getting back to me. Strangely, the worksheet will count symbols nested in a group, so I've got around the problem by using groups of symbols, rather than nested ones. This workaround will see me right for this project, but it seems like it should be a pretty easy one to address for the development team? Cheers, Nick Quote Link to comment
Pat Stanford Posted November 3, 2016 Share Posted November 3, 2016 It seems to work for me in the attached file at least with database rows. I think I am doing exactly the same thing you are, but take a look at the file and see what I did and see if it makes a difference. This is a VW2017 file. InSymbol Test 2017.vwx Quote Link to comment
NickS Posted July 5, 2018 Share Posted July 5, 2018 Hi @Pat Stanford, I know this is a bit old, but have come across this one myself now. I interact with VW worksheets to cost out playground jobs and produce fabrication lists of symbols, so I have a vested interest in getting to the bottom of this. I have had a play with your sample document and have not been able to reproduce the issue, however I have been able to reproduce in my own documents and I believe it may be something to do with the shape/size of the object which defines the location. I'm unable to attach the screen capture here for some reason so I have included a link to the video on GD (https://drive.google.com/file/d/1zgDb1CYLckKgMDGoiZSKiyNF7k5Eu2K8/view?usp=sharing) Not sure why it behaves like this; ideas? My only thought is that the symbols I am using exist in 3D, which maybe affects it somehow?? @knickers I know this is an old one now, but can you have a look at the video and see if you get the same behaviour? Quote Link to comment
JMR Posted July 7, 2018 Share Posted July 7, 2018 The LOC function is picky about the z value. Symbols have to be on the same plane as the location defining object is. I guess for 3D symbols their insertion point z value should be the same as the location defining object z. For example, if a space object is a bit off from the layer plane z, the LOC function won't planar symbols on the layer plane. As far as I know. Quote Link to comment
