Ethan R.
Wall Schedule - Name Walls in Worksheet ?
Hi - Trying to create a wall schedule - and I want to name some walls for clarification.
Trying to create a Name (IFC Field in the OIP??)
and then pull it on the report?
Can someone give me the right location for the name and syntax for the report?
Thank you :)
Ethan
So easy - so perfect
THANK YOU !!!!
is there a list of all the references somewhere?
I feel as if they are very hard to figure out what each one is.
ty
Ethan
This is what is referred to as a "Criteria Arguments" in the help.
Do a search in the VW Help for "Worksheet Functions" and then follow the links to two developer.vectorworks.net pages. This will give you a lot more information.
The most useful of these (IMNOHO) are:
=N    Name
=L    Layer
=C    Class
=T   Object Type (but this will give you a numeric code, not the name of the type).
is there a good tutorial on this?
I found the "wall report" tutorial - but it does not really show the "how" to construct arguments - just a lot of 'do this"
thanksl
OMG Thank you !
It seems that there should be a good reference for this.
I'm not trying to reference
Sheet Number
Sheet Title
Sheet Description
Seems like it is a no brainer somehow ?? but i can't find it.
Can someone point me to the correct syntax?
