- 0
Sheet Border/ Title Block not linking to title in single file
Asked by
Asemblance
Asked by
Asemblance
7150 Riverwood Drive, Columbia, Maryland 21046, USA | Contact Us: 410-290-5114
© 2018 Vectorworks, Inc. All Rights Reserved. Vectorworks, Inc. is part of the Nemetschek Group.
Hi all,
I'm having a bit of an issue with Sheet Titles on Sheet Borders/Titles Blocks.
I've recently set up new title blocks with linked record files, so that the title block takes its name from the sheet name etc. This has been working OK, until I tried to make some changes to the blocks today.
Since this, one of the files I have been working on refuses to link title block to sheet title information etc. I can only assume somethings going on with some broken reference or duplicated symbol id#. I thought I would simply make a new title block in the default sheet border/title block file, with a new record file, and a new name, and use this. However the new block I created still does not work with this one particular file. It DOES work with other files, i.e. if I create a new file, add a sheet border, pick the new title block; this will create the appropriate Sheet no, sheet name etc links.
Any ideas??
Thanks,
Anthony
