  • 2
Michael H.
VW2017 Resource Manager catalog does not update
I installed VW 2017 (which had SP1 included) and the resource manager catalog fails to update (it stops at 14%). I receive a message box that the default content could not be updated and to verify if I have write access to the application libraries. I checked the security dialog box in the file properties and my user account has full read/write access. I tried running VW as an administrator and still the same problem. I also tried the administrator account to see if VW would work and nope - it won't update the catalog.
Since the resource browser cannot update with the default content, all plug-in objects, attributes etc. do not show symbols, hatches, textures etc. The selection boxes are greyed out. Basically VW2017 is unusable.
I also installed VW2017 on my HP notebook to see if it would work - nope, same problem. Any ideas on how to resolve this?
20 answers to this question
Having the same issue aswell, my local distributer gave me this link of others and some question from Jim which they sent off. Hopefully will be fixed soon.
For any with this issue, please reply back with the following:
http://kbase.vectorworks.net/questions/627/DirectX+Diagnostics+and+System+Profiler
And also engineering asks to clarify: Did you EVER have an installation of Vectorworks 2017 prior to the full installer that also included SP1? Or were your only installations from the 2017 SP1 installer in the first place?
No to the first, yes to the second. First install was the NZ version of 2017, which came with SP1.
This is happening on every computer in the office. I've attached system profiles for two of them (the rest are similar machines).
iMac.spx
Mac_mini.spx
Followup questions from engineering:
"Could you, please, ask if he has defaultContent.db, defaultContent.db.proxy files in his Libraries folder?
And just in case can he check the Permissions for the Library folder?"
(To check the permissions of the Library folder, right click on it and choose "Get Info" and then post a screenshot of the permissions on the bottom please.)
I have both those files in the Libraries folder.
Permissions are 0777 (I was seeing if this would help, the answer is no):
drwxrwxrwx   22 three  admin     748 28 Oct 09:13 Libraries
Hi Jim
Attached is a file containing the DirectX diagnostic file plus images of the my file security permissions for the libraries folder.
In the Libraries folder there are two files:
vwlibraries.db.proxy
vwlibraries.zip
I haven't had a previous installation of VW2017, as per yomcat's reply this is the New Zealand version of VW2017 which already came with SP1 included (build 333939).
Thanks.
VW2017-NZ.zip
Hello guys,
I'm from the engineering team. Thanks for the help.
Could you, please, provide me with these (defaultContent.db, defaultContent.db.proxy) files?
Thanks
On 10/29/2016 at 4:03 AM, Lada said:
Hello guys,
Thanks
Ah. I don't actually have those files. I just looked at the extensions, not the file names. My apologies.
Ten:Libraries three$ ls -a
.					Objects - Entertainment Controls
..					Objects - Entertainment Stage_Event
.DS_Store				Objects - Entertainment Truss
Defaults				Objects - Landscape & Site
Object Styles				Objects - Landscape Plants
Objects - Architecture			Objects - Landscape Site
Objects - Building Equip_Appliances	Objects - Miscellaneous_Entourage
Objects - Building Equip_Furnishings	Renderworks Cameras
Objects - Building Furnishings		VWLIB_IMGPACK
Objects - Building Services		vwlibraries.db
Objects - Entertainment Audio		vwlibraries.db.proxy
Should I upload the vwlibraries files somewhere?
Did you try the "Refresh libraries" command? It is in the action menu of the Resource manager.
Just tried it. It appeared to run, didn't throw an error (or any other output), but no change -- there's still no default content and the three dialogs in the opening post still pop up upon reopening VectorWorks.
I gave it a go. A message box shows that it's updating the subscription libraries, though there's no indication in the progress bar. The message box closes and still no update.
I checked VW user log and there appears to be a lot of network errors relating to the library files. Not sure if that helps.
Do folders have a content? If yes, could you, please, attach any .vwx file from Defaults/.. or Object styles/.. folder?
Yes, all folders have content. For example, here's the listing of the Defaults folder:
Ten:Defaults three$ ls -FR
Attributes - Gradients/		Renderworks - Backgrounds/
Attributes - Hatches/		Renderworks - Textures/
Attributes - Image Fills/
./Attributes - Gradients:
ANZ-Corrugated Roofing.vwx	Tone Variations.vwx
Miscellaneous.vwx
./Attributes - Hatches:
ANZ-Anston Paving Stone.vwx	Parquetry.vwx
ANZ-Paving.vwx			Paving Bricks-1.vwx
Brickwork with Joints.vwx	Paving Bricks-2.vwx
Civil Engineering.vwx		Plan Shading.vwx
Miscellaneous-2.vwx		Urban Planning.vwx
./Attributes - Image Fills:
Asphalt/	Glass/		Misc/		Siding/		Wood/
Ceiling/	Landscaping/	Paint/		Stucco_Plaster/
Concrete/	Masonry/	Paver/		Textiles/
Flooring/	Metals/		Roofing/	Tile/
./Attributes - Image Fills/Asphalt:
_Asphalt.vwx
./Attributes - Image Fills/Ceiling:
_Ceiling.vwx
./Attributes - Image Fills/Concrete:
Concrete-2.vwx
Holcim mtextur 01.vwx
Holcim mtextur 02.vwx
_Concrete.vwx
arroway-textures Concrete Volume 01a.vwx
arroway-textures Concrete Volume 01b.vwx
arroway-textures Concrete Volume 01c.vwx
arroway-textures Concrete Volume 01d.vwx
arroway-textures Concrete Volume 02a.vwx
arroway-textures Concrete Volume 02b.vwx
arroway-textures Concrete Volume 02c.vwx
./Attributes - Image Fills/Flooring:
Forbo-Artoleum.vwx
Forbo-Effect.vwx
Forbo-Eternal.vwx
Forbo-Marmoleum 01.vwx
Forbo-Marmoleum 02.vwx
Forbo-Marmoleum 03.vwx
Forbo-Marmoleum 04.vwx
Forbo-Marmoleum 05.vwx
Forbo-Marmoleum 06.vwx
Forbo-Marmoleum 07.vwx
Forbo-Marmoleum 08.vwx
Forbo-Smaragd.vwx
Rubber.vwx
_Bamboo Flooring.vwx
_Carpet.vwx
_Marble Flooring.vwx
_Vinyl Flooring.vwx
arroway-textures Wood Floor Volume 01a.vwx
arroway-textures Wood Floor Volume 01b.vwx
arroway-textures Wood Floor Volume 02a.vwx
arroway-textures Wood Floor Volume 02b.vwx
./Attributes - Image Fills/Glass:
Glass Blocks.vwx	_Glass.vwx
./Attributes - Image Fills/Landscaping:
Sky.vwx		Vegetation.vwx	Water.vwx	_Landscape.vwx
./Attributes - Image Fills/Masonry:
Bricks IF.vwx
Natural Stone.vwx
_Brick.vwx
_CMU.vwx
_Stone 01.vwx
_Stone 02.vwx
_Stone 03.vwx
arroway-textures Bricks 01.vwx
arroway-textures Bricks 02.vwx
arroway-textures Stonework Volume 01a.vwx
arroway-textures Stonework Volume 01b.vwx
arroway-textures Stonework Volume 01c.vwx
arroway-textures Stonework Volume 02a.vwx
arroway-textures Stonework Volume 02b.vwx
arroway-textures Stonework Volume 02c.vwx
arroway-textures Stonework Volume 03a.vwx
arroway-textures Stonework Volume 03b.vwx
./Attributes - Image Fills/Metals:
Metal.vwx	_Metal.vwx
./Attributes - Image Fills/Misc:
Facades.vwx
Marble.vwx
Miscellaneous.vwx
Various.vwx
arroway-textures Building Materials 01.vwx
arroway-textures Building Materials 02.vwx
arroway-textures Building Materials 03.vwx
arroway-textures Building Materials 04.vwx
./Attributes - Image Fills/Paint:
_Paint.vwx
./Attributes - Image Fills/Paver:
Paving.vwx	_Paver.vwx
./Attributes - Image Fills/Roofing:
Roof Tiles.vwx	_Roofing.vwx
./Attributes - Image Fills/Siding:
_Siding.vwx
./Attributes - Image Fills/Stucco_Plaster:
Textured Finishes.vwx			arroway-textures Plaster 02.vwx
_Stucco.vwx				arroway-textures Plaster 03.vwx
arroway-textures Plaster 01.vwx
./Attributes - Image Fills/Textiles:
Textiles.vwx	_Fabrics.vwx
./Attributes - Image Fills/Tile:
Ceramic Tiles.vwx			arroway-textures Tiles Volume 01c.vwx
_Tile 01.vwx				arroway-textures Tiles Volume 02a.vwx
_Tile 02.vwx				arroway-textures Tiles Volume 02b.vwx
arroway-textures Tiles Volume 01a.vwx	arroway-textures Tiles Volume 02c.vwx
arroway-textures Tiles Volume 01b.vwx
./Attributes - Image Fills/Wood:
Wood Arcitex.vwx			arroway-textures Wood Volume 01e.vwx
Wood-Boards.vwx				arroway-textures Wood Volume 02a.vwx
Wood-Parquet.vwx			arroway-textures Wood Volume 02b.vwx
Wood.vwx				arroway-textures Wood Volume 02c.vwx
_Wood Decking.vwx			arroway-textures Wood Volume 02d.vwx
arroway-textures Wood Volume 01a.vwx	arroway-textures Wood Volume 04a.vwx
arroway-textures Wood Volume 01b.vwx	arroway-textures Wood Volume 04b.vwx
arroway-textures Wood Volume 01c.vwx	arroway-textures Wood Volume 04c.vwx
arroway-textures Wood Volume 01d.vwx	arroway-textures Wood Volume 04d.vwx
./Renderworks - Backgrounds:
HDRI Backgrounds 02.vwx
./Renderworks - Textures:
Asphalt/	Flooring/	Metals/		Plastics/	Textiles/
Ceiling/	Glass/		Misc/		Roofing/	Tile/
Ceramic/	Landscaping/	Paint/		Siding/		Wood/
Concrete/	Masonry/	Paver/		Stucco_Plaster/
./Renderworks - Textures/Asphalt:
_Asphalt.vwx
./Renderworks - Textures/Ceiling:
_Ceiling.vwx
./Renderworks - Textures/Ceramic:
Ceramic-2.vwx	_Ceramic.vwx
./Renderworks - Textures/Concrete:
Concrete-2.vwx
_Concrete.vwx
arroway-textures Concrete Volume 01e.vwx
arroway-textures Concrete Volume 01f.vwx
arroway-textures Concrete Volume 02d.vwx
arroway-textures Concrete Volume 02e.vwx
./Renderworks - Textures/Flooring:
Forbo-Artoleum.vwx
Forbo-Effect.vwx
Forbo-Eternal.vwx
Forbo-Marmoleum Corkment.vwx
Forbo-Marmoleum Dual.vwx
Forbo-Marmoleum Fresco.vwx
Forbo-Marmoleum Piano.vwx
Forbo-Marmoleum Real.vwx
Forbo-Marmoleum Vivace.vwx
Forbo-Marmoleum Walt.vwx
Forbo-Smaragd.vwx
Parquet Flooring.vwx
Rubber.vwx
_Carpet.vwx
_Vinyl Flooring.vwx
_Wood Flooring.vwx
arroway-textures Wood Floor Volume 01c.vwx
arroway-textures Wood Floor Volume 01d.vwx
arroway-textures Wood Floor Volume 01e.vwx
arroway-textures Wood Floor Volume 01f.vwx
arroway-textures Wood Floor Volume 02c.vwx
arroway-textures Wood Floor Volume 02d.vwx
arroway-textures Wood Floor Volume 02e.vwx
./Renderworks - Textures/Glass:
Glass-2.vwx	_Glass.vwx
./Renderworks - Textures/Landscaping:
Sky.vwx					_Grass Displacement Map 02.vwx
Vegetation.vwx				_Grass Displacement Map 03.vwx
Water.vwx				_Grass Displacement Map 04.vwx
_Foliage Displacement Map 01.vwx	_Grass Shaders.vwx
_Foliage Displacement Map 02.vwx	_Landscape.vwx
_Grass Displacement Map 01.vwx
./Renderworks - Textures/Masonry:
ANZ-Brick Boral NSW.vwx
ANZ-Brick Boral WA Midland.vwx
Brick-European.vwx
_Brick.vwx
_Bricks Shaders.vwx
_CMU.vwx
_Stone 01.vwx
_Stone 02.vwx
_Stone 03.vwx
arroway-textures Bricks 03.vwx
arroway-textures Bricks 04.vwx
arroway-textures Stonework Volume 01d.vwx
arroway-textures Stonework Volume 01e.vwx
arroway-textures Stonework Volume 01f.vwx
arroway-textures Stonework Volume 02d.vwx
arroway-textures Stonework Volume 02e.vwx
arroway-textures Stonework Volume 03c.vwx
arroway-textures Stonework Volume 03d.vwx
./Renderworks - Textures/Metals:
Metals-1.vwx	Metals-2.vwx	_Metals.vwx
./Renderworks - Textures/Misc:
Marble.vwx
Various.vwx
_Miscellaneous.vwx
arroway-textures Building Materials 05.vwx
arroway-textures Building Materials 06.vwx
./Renderworks - Textures/Paint:
_Paint.vwx
./Renderworks - Textures/Paver:
Cambridge Pavers Excalibur Collection.vwx
Cambridge Pavers KingsCourt Collection.vwx
Cambridge Pavers Renaissance Collection 01.vwx
Cambridge Pavers Renaissance Collection 02.vwx
Cambridge Pavers RoundTable Collection 01.vwx
Cambridge Pavers RoundTable Collection 02.vwx
Cambridge Pavers Sherwood Collection 01.vwx
Cambridge Pavers Sherwood Collection 02.vwx
Cambridge Pavers Wall Stone 01.vwx
Cambridge Pavers Wall Stone 02.vwx
Natural Stone.vwx
Pavement RINN 01.vwx
Pavement RINN 02.vwx
Pavement RINN 03.vwx
Paving.vwx
_Pavers.vwx
./Renderworks - Textures/Plastics:
_Plastics.vwx
./Renderworks - Textures/Roofing:
ANZ-Bristile Concrete Roof Tiles East Coast.vwx
Roofing Tiles-European.vwx
_Roofing.vwx
./Renderworks - Textures/Siding:
_Siding.vwx
./Renderworks - Textures/Stucco_Plaster:
Textured Finishes.vwx			arroway-textures Plaster 03.vwx
_Stucco.vwx				arroway-textures Plaster 04.vwx
arroway-textures Plaster 01.vwx		arroway-textures Plaster 05.vwx
./Renderworks - Textures/Textiles:
./Renderworks - Textures/Tile:
_Tile 01.vwx				arroway-textures Tiles Volume 01e.vwx
_Tile 02.vwx				arroway-textures Tiles Volume 02a.vwx
arroway-textures Tiles Volume 01a.vwx	arroway-textures Tiles Volume 02b.vwx
arroway-textures Tiles Volume 01b.vwx	arroway-textures Tiles Volume 02c.vwx
arroway-textures Tiles Volume 01c.vwx	arroway-textures Tiles Volume 02d.vwx
arroway-textures Tiles Volume 01d.vwx	arroway-textures Tiles Volume 02e.vwx
./Renderworks - Textures/Wood:
Arcitex Wood.vwx			arroway-textures Wood Volume 02b.vwx
Wood-Boards.vwx				arroway-textures Wood Volume 02c.vwx
Wood.vwx				arroway-textures Wood Volume 02d.vwx
_Wood Board.vwx				arroway-textures Wood Volume 02e.vwx
_Wood Decking.vwx			arroway-textures Wood Volume 02f.vwx
_Wood Paneling.vwx			arroway-textures Wood Volume 03a.vwx
_Wood Veneer.vwx			arroway-textures Wood Volume 03b.vwx
arroway-textures Wood Volume 01a.vwx	arroway-textures Wood Volume 03c.vwx
arroway-textures Wood Volume 01b.vwx	arroway-textures Wood Volume 03d.vwx
arroway-textures Wood Volume 01c.vwx	arroway-textures Wood Volume 03e.vwx
arroway-textures Wood Volume 01d.vwx	arroway-textures Wood Volume 03f.vwx
arroway-textures Wood Volume 01e.vwx	arroway-textures Wood Volume 04a.vwx
arroway-textures Wood Volume 01f.vwx	arroway-textures Wood Volume 04b.vwx
arroway-textures Wood Volume 01g.vwx	arroway-textures Wood Volume 04c.vwx
arroway-textures Wood Volume 01h.vwx	arroway-textures Wood Volume 04d.vwx
arroway-textures Wood Volume 01i.vwx	arroway-textures Wood Volume 04e.vwx
I've attached ANZ-Paving from Attributes - Hatches.
ANZ-Paving.vwx
This might be relevant. I went and had a look at the User Library folder (the one buried in ~/Library/Application Support) and it's got a bunch of folders, all of which are empty:
Ten:~ three$ cd Library/Application\ Support/Vectorworks/2017/Libraries/Defaults
Ten:Defaults three$ ls -RL
Attributes - Gradients				Record Formats
Attributes - Hatches				Renderworks - Backgrounds
Attributes - Image Fills			Renderworks - Render Styles
Attributes - Line Types				Renderworks - Textures
Attributes - Tile Fills				Repetitive Unit
Audio Tools					Reports_Schedules
BIMobject					Seating Layout - Symbols
Cabinet - Handles				Section - Markers
Cable Tools					Sheet Border - Title Blocks
Color Palettes					Sketch Styles
Detail Callout-Marker				Slab Drainage
Door - Custom Leaves				Soft Goods - Custom Textures
Door - Hardware					Space
Energy Analysis					Stage Deck
Event Planning					Stairs
Existing Tree					Stairs - Custom Stair Tool
Focus Points					Stairs - Custom Stair Tool - Stringer Profiles
Framing Member - Custom Profile			Standards
Hardscape - Hatches				Story Support
Heliodon					Structural Shapes
Hoist Tools					Tag-Label
Human Figure - Textures				Templates
Interior Elevation Marker			Text Styles
Irrigation					Tile - Symbols
Lighting Instrument - Gobos			Toilet Stall - Fixtures
Marionette					VAA Title Blocks
Notes						Video Screen
Parking Space					Walls_Slabs_Roofs - Hatches
Plants - Hatches				Walls_Slabs_Roofs - Textures
Railing Fence					Window - Custom Shutters
./Attributes - Line Types:
./Attributes - Tile Fills:
./Audio Tools:
Bumpers		Speakers
./Audio Tools/Bumpers:
./Audio Tools/Speakers:
./BIMobject:
./Cabinet - Handles:
./Cable Tools:
Break Out Labels	Marker Symbols		Multi Head Symbols
./Cable Tools/Break Out Labels:
./Cable Tools/Marker Symbols:
./Cable Tools/Multi Head Symbols:
./Color Palettes:
./Detail Callout-Marker:
./Door - Custom Leaves:
./Door - Hardware:
./Energy Analysis:
Building Envelope
./Energy Analysis/Building Envelope:
Building Element Roof Boundary Type	Building Element WinDoor Frame
Building Element Wall Boundary Type	Building Element WinDoor Glazing
./Energy Analysis/Building Envelope/Building Element Roof Boundary Type:
EU_Generic.xml
./Energy Analysis/Building Envelope/Building Element Wall Boundary Type:
EU_Generic.xml
./Energy Analysis/Building Envelope/Building Element WinDoor Frame:
EU_Framing_Defaults.xml
./Energy Analysis/Building Envelope/Building Element WinDoor Glazing:
EU_Glazing_Defaults.xml
./Event Planning:
Lectern	Room	Screen	Seating	Stage	Step
./Event Planning/Lectern:
./Event Planning/Room:
./Event Planning/Screen:
./Event Planning/Seating:
./Event Planning/Stage:
./Event Planning/Step:
./Existing Tree:
./Focus Points:
./Framing Member - Custom Profile:
./Hardscape - Hatches:
./Heliodon:
Cities	Symbols
./Heliodon/Cities:
./Heliodon/Symbols:
./Hoist Tools:
./Human Figure - Textures:
./Interior Elevation Marker:
./Irrigation:
Catalogs	Saved Content	Symbols
./Irrigation/Catalogs:
./Irrigation/Saved Content:
Controllers		Outlets			Points of Connection	Valves
Drip Outlets		Pipes			System Components
./Irrigation/Saved Content/Controllers:
./Irrigation/Saved Content/Drip Outlets:
./Irrigation/Saved Content/Outlets:
./Irrigation/Saved Content/Pipes:
./Irrigation/Saved Content/Points of Connection:
./Irrigation/Saved Content/System Components:
./Irrigation/Saved Content/Valves:
./Irrigation/Symbols:
Controllers		Points of Connection	Valves
Outlets			System Components
./Irrigation/Symbols/Controllers:
./Irrigation/Symbols/Outlets:
./Irrigation/Symbols/Points of Connection:
./Irrigation/Symbols/System Components:
./Irrigation/Symbols/Valves:
./Lighting Instrument - Gobos:
./Marionette:
Attributes$	Math$		Objects		Textures$
./Marionette/Attributes$:
./Marionette/Math$:
./Marionette/Objects:
NURBS$
./Marionette/Objects/NURBS$:
./Marionette/Textures$:
./Notes:
./Parking Space:
./Plants - Hatches:
./Railing Fence:
Profile Posts		Profile Top Rail	Railing Fence		Symbol Posts
./Railing Fence/Profile Posts:
./Railing Fence/Profile Top Rail:
./Railing Fence/Railing Fence:
Fence	Railing
./Railing Fence/Railing Fence/Fence:
./Railing Fence/Railing Fence/Railing:
./Railing Fence/Symbol Posts:
./Record Formats:
./Renderworks - Render Styles:
./Repetitive Unit:
Flooring~Decking	Masonry Units		Roofing
Framing			Miscellaneous		Siding
./Repetitive Unit/Flooring~Decking:
./Repetitive Unit/Framing:
./Repetitive Unit/Masonry Units:
./Repetitive Unit/Miscellaneous:
./Repetitive Unit/Roofing:
./Repetitive Unit/Siding:
./Reports_Schedules:
Landmark Schedules	Spotlight Schedules
./Reports_Schedules/Landmark Schedules:
./Reports_Schedules/Spotlight Schedules:
./Seating Layout - Symbols:
./Section - Markers:
./Sheet Border - Title Blocks:
./Sketch Styles:
./Slab Drainage:
./Soft Goods - Custom Textures:
./Space:
Space - GSA			Space - Space Name		Space - Zone
Space - Occ Organization	Space - Stamp
Space - Room Finishes		Space - Style
./Space/Space - GSA:
Category	Occupancy Orgs	OmniClass	Type
./Space/Space - GSA/Category:
./Space/Space - GSA/Occupancy Orgs:
./Space/Space - GSA/OmniClass:
./Space/Space - GSA/Type:
./Space/Space - Occ Organization:
./Space/Space - Room Finishes:
Base	Ceiling	Floor	Walls
./Space/Space - Room Finishes/Base:
./Space/Space - Room Finishes/Ceiling:
./Space/Space - Room Finishes/Floor:
./Space/Space - Room Finishes/Walls:
./Space/Space - Space Name:
./Space/Space - Stamp:
./Space/Space - Style:
./Space/Space - Zone:
./Stage Deck:
./Stairs:
./Stairs - Custom Stair Tool:
./Stairs - Custom Stair Tool - Stringer Profiles:
./Standards:
./Story Support:
./Structural Shapes:
./Tag-Label:
./Templates:
./Text Styles:
./Tile - Symbols:
./Toilet Stall - Fixtures:
./VAA Title Blocks:
VAA North Points
./VAA Title Blocks/VAA North Points:
./Video Screen:
Casings CRT 16-9	Casings CRT Curved 4-3	Casings Flat 4-3	Screen Images
Casings CRT 4-3		Casings Flat 16-9	Projector Models	Stand Models
./Video Screen/Casings CRT 16-9:
./Video Screen/Casings CRT 4-3:
./Video Screen/Casings CRT Curved 4-3:
./Video Screen/Casings Flat 16-9:
./Video Screen/Casings Flat 4-3:
./Video Screen/Projector Models:
./Video Screen/Screen Images:
./Video Screen/Stand Models:
./Walls_Slabs_Roofs - Hatches:
./Walls_Slabs_Roofs - Textures:
./Window - Custom Shutters:
The resource manager shows folders with files but there are no actual files on the computer. Vectorworks libraries folder on has two files in it and the User Libraries has lots of folders but they are empty.
It's working now! Apparently there was a problem with the installer and a new installer was provided to our local distributor.
Thanks to tech support for sorting this out. Much appreciated.
On 11/24/2016 at 2:45 AM, Bas Vellekoop said:
With SP2 everything works as expected! WhoopWhoop!
VW 2017 SP2
iMac (27-inch, Late 2013)
3.5 GHz Intel Core i7
24 GB 1600 MHz DDR3
NVIDIA GeForce GTX 780M 4096 MB
service select
Resource manager not allowing me to use textures. I've changed permissions for write access in application library.
(Haven't checked other resources availability)
-Henry
58ded3adb0c2c_VWresourcemanagermessage31mar17.jpg.23d2d840f220e6a8421dae3070468a2f.jpg
On 3/31/2017 at 6:13 PM, Henry Finch said:
VW 2017 SP2
24 GB 1600 MHz DDR3
service select
-Henry
You'll most likely need to give Read/Write to all subfolders within the Vectorworks user folder as well, not just the Application folder.
