Jordan Grimes Posted October 25, 2016 Share Posted October 25, 2016 All my hoist in a file have turned black with white fill in top/plan. I don't believe i did anything to make this happen. Any ideas? Freedom_Fest_2016.zip Quote Link to comment
michaelk Posted October 25, 2016 Share Posted October 25, 2016 The classes Hoist Color-Audio, -Lights, -Scenery, and -Video are set to invisible. Make those visible and the color will come back. hth mk 1 Quote Link to comment
Andy Broomell Posted October 25, 2016 Share Posted October 25, 2016 Also note that those classes are saved as Invisible in the two Saved Views, so every time you run those views it's going to turn the classes off again. Fastest way to fix is to select the four classes, right click, choose Visibilities, and turn them on in the Saved Views. Or if you want them off in those Saved Views, make an additional Saved View that takes you to your Groundplan with all your classes on that you want. 1 Quote Link to comment
Jordan Grimes Posted October 25, 2016 Author Share Posted October 25, 2016 Thanks, this is def the problem. I don't make a habit of setting classes to invisible so I didn't think to look there. Still learning, def loving Vectorworks over autoCAD. Quote Link to comment
