Guest Wes Gardner
I don't believe the shutters have the ability to be parametrically set.  I think they are "always open".  The sash, as you've seen, can be set to an angle in 3D.
I guess without the widow shutter being able to be open or closed you will have to resort to placing them on manually or Marionette. In the attached file click on the shutters and in the OIP change the opening angle.
This is a rough example and does not take into consideration the width or height of the opening nor have I limited the opening angle to 180Deg. All possible, just copy the shutters to another window. If this is an option that will assist I can set up something that will show you how to create different shutter shapes that can fit various window sizes.
The second file will adjust to suite the width of the window when you change the shutter opening angle.
HTH
161023_02_v2016.vwx
161023_03_v2016.vwx
Edited by Alan Woodwell
