BG Posted October 20, 2016 Share Posted October 20, 2016 Hi What is the correct way to align the surface hatch on a wall that is above another wall? Thanks Quote Link to comment
P Retondo Posted October 20, 2016 Share Posted October 20, 2016 (edited) Are these hatches or textures? Edited October 20, 2016 by P Retondo Quote Link to comment
P Retondo Posted October 20, 2016 Share Posted October 20, 2016 I guess these are hatches associated with a texture. In playing with this type of thing, I can see it makes a difference whether you have selected "Plane" or "Auto-align plane" in the Render tab of the OIP. "Auto-align plane" seems to line things up correctly, where "Plane" can put things out of whack. Quote Link to comment
BG Posted October 20, 2016 Author Share Posted October 20, 2016 Hi. It's a surface hatch associated with a render texture. Both hatches had 'auto-align plan' selected. I adjusted the hatch on the wall above using the 'Offset H' field in the OIP and that seems to have it close enough. I was really just wondering if there was a "correct" method to align surface hatches. Thanks Quote Link to comment
dtheory Posted April 8, 2020 Share Posted April 8, 2020 I'd like to bump this topic.. I've tried a number of strategies here, without a bombproof solution. texture mapping mode consistent between floors, attribute mapping tool used to align the texture bitmap.. Often the hatch is still not aligned between floors.. Anyone have a reliable repeatable method here? Quote Link to comment
