Ariel Posted September 11, 2003 Share Posted September 11, 2003 OS9.2, which is the required minimum for the VW10.5 updater, is not supported on my g4-upgraded powermac 8500. Does this really mean that I'm now stuck using VW10.1.2? Ariel Quote Link to comment
almac Posted September 14, 2003 Share Posted September 14, 2003 I am running VW 10.1.2 on a Powermac 6100 upgraded with a Newer Technology G3 300 Mhz card and can only upgrade to O.S. 9.1, also. You're not telling me that I won't be able to upgrade to VW 10.5, are you? I have not attempted to upgrade, yet, because I normally don't install VW upgrades until I'm finished a job and it's safely stored on a CD! Anyone else in a similar situation? Quote Link to comment
rjtiedeman Posted September 15, 2003 Share Posted September 15, 2003 Ariel, I have been using an upgraded PowerMac 9500 with a Maxpower 400 upgrade. I tried the system 9 helper that was mentioned in a previous post. It allows you to 9.21 on an old world MAC. The system 9 helper worked but my 9500 was very flaky and 10.5 ran very slow and locked up frequently. Don't waste you time. We have to buy new Macs to take advantage of the 10.5 update. Bob Tiedemann Quote Link to comment
Administrator Pharr Posted September 15, 2003 Administrator Share Posted September 15, 2003 To use VW 10.5, you will need to run MacOS 9.2 or later. If this implies you will need to upgrade machines, then yes, you are stuck with 10.1.2 until you modernize your hardware. Paul Pharr NNA Quote Link to comment
Katerina Posted September 15, 2003 Share Posted September 15, 2003 i used the os9 helper to update to 9.2 and all is o.k. Quote Link to comment
