My staff is reporting, and I have seen it myself - a lag in 2D graphical updating after certain operations - most noticeably after 'reshape.' If you have a polygon - and you use the reshape tool - the polygon entity does seem to change - but it is still displayed as the unmodified polygon. This is evident when you go to select the polygon - the old moved line will not allow selection - but the invisible new line will - and it will highlight the new shape.
Nudging the object forces the redraw and corrects the graphic - but this is an issue.
