RMDiekmann Posted October 17, 2016 Share Posted October 17, 2016 I have to say thank you for adding the ability to set your own class default structure for parts in 2017. I found one that is missing unless I completely overlooked it. Please add the Multicable pointer to the dropdown for Parts classing in the OIP. Quote Link to comment
Sam Jones Posted November 29, 2016 Share Posted November 29, 2016 You each instance of the multi is assigned either: a) the active class or b) the default class for the Multicable VW plug-in object. You can specify the default class using the Plug-in Manager. 1. Go to Tools > Plug-ins > Plug-in Manger... 2. In the resulting dialog, select the "Built-in Plug-ins" tab 3. In the resulting list, select the "Multicable VW" object 4. Click on the "Cusomize..." button 5. In the resulting dialog, click on the "Properties" tab at the top of the dialog. 6. Type the name of the class you want multicables to default to. 7. Close all the dialogs. HTH, Sam Quote Link to comment
