I fear this will make me seem completely clueless but even as I've used Vectorworks for decades I have never installed a 3rd party plugin and am not sure exactly how to do so. I found a Velux skylight from bimobject to download and it is a plugin, which I assume will then include some adjustable parameters to the skylight object. Regardless of this specific plugin, I think it is high time that I finally learned this to be able to access what seems to be a whole world of available useful plugins out there.
I see that I need to go to Tools>Plug-ins>Plug-in Manager and here is where I get lost. The downloaded file is a folder containing four items: a folder labeled -VMS Data containing 10 .txt scripts; a EmbedAH.qtr (I don't know exactly what this is) file describing a bunch of stuff about the geometry and display of the object; a Embed.rsrc executable file; and then the actual Velux Modular Skylight.vso plugin. When in the Plug-in manager I would assume I select >third party plugins>install and then locate the folder but in doing so everything is greyed in the folder. This is all I know.
Is the folder supposed to be available to install or just the actual .vso file, and how do you know what type of object it is to select when you get to that dialogue box, and then how do you find it and use it if you successfully install it? And if you just install the .vso file, what do you do with the other stuff in the folder?
I'm sure this is not particularly complicated but just need one clear explanation of the process.
Thanks very much in advance for someone hopefully rolling their eyes but being able to clearly explain the basics I am missing.
Edit: I'm not even sure if this is the correct forum to post this so moderators please move if necessary to get a quicker response.- thanks!
