aozhouyyq1982 Posted October 14, 2016 Share Posted October 14, 2016 (edited) Hi all, Anyone knows how to control the line weight to be shown EXACTLY as we set up on screen. I already set the line 3mm width that is displayed ridiculous wide on screen, but when i issue it to pdf, it looks wider but not as I expected. it always looks thinner... thanks ______________________________________________________ VW 2016 SP4 MAC. Edited October 14, 2016 by aozhouyyq1982 Quote Link to comment
AlanW Posted October 14, 2016 Share Posted October 14, 2016 Hi, Hope this helps to solve your problem. Presentation1.mp4 Quote Link to comment
aozhouyyq1982 Posted October 14, 2016 Author Share Posted October 14, 2016 1 hour ago, Alan Woodwell said: Hi, Hope this helps to solve your problem. Presentation1.mp4 Thanks Alan, It is exactly the problem frustrated me. the presentation you uploaded solve the issue, but the line weight in VW is really hard to control... thanks again. Quote Link to comment
AlanW Posted October 15, 2016 Share Posted October 15, 2016 (edited) I usually set my design layer the same scale as my viewport. Generally use the 1:100; Line weights I have the usual 7 Line weights .09 to 0.7, then all the rest i set to 0.05. Why some will disagree, well how often have you looked a 3D viewport and you have a thick line next to the window because you have the walls set to 0.35. If needed i control all through the viewport and by class. With all the same lineweight i get a better hidden line render. My final renders I very rarely have the lines turned on. HTH Edited October 15, 2016 by Alan Woodwell Quote Link to comment
