I don't want to use a tick size, mass outline, etc.  Most of these I want set to none, however all the plants have these settings turned on when I place them.  Is there some way to make the default none?  The amount of time spent changing these 10 boxes for every plant on every file is immense.  Thank you.
Edited by kufuffin
I got an answer from tech support.  Apparently in Plant tool>wrench> annotation  you can turn on/off settings for the tool to use on every plant.  When opening a file these settings change to something random since I last used them so I have to manually change all the settings back to none.
