Mike Wright Posted October 13, 2016 Share Posted October 13, 2016 in VW2017 the 'insert screen' from the Event Design drop down no longer seems to work. It will insert the symbol for the selected screen but it does not appear as a screen object so cannot be edited as such. The command does work if you use the screen object tool from the Spotlight tool palette. Quote Link to comment
markdd Posted October 13, 2016 Share Posted October 13, 2016 The menu command works fine here. The tool command needed a bit of a view change to render properly, but this was the first time I have used it so feeling very forgiving! Quote Link to comment
Mike Wright Posted October 13, 2016 Author Share Posted October 13, 2016 interesting I've attached a file with a screen inserted from the menu command and one from the tool palette for reference screen tool.vwx Quote Link to comment
Mike Wright Posted October 13, 2016 Author Share Posted October 13, 2016 I think this is probably a workspace migration issue, hopefully JimW will descend with his halo and help out soon! Quote Link to comment
markdd Posted October 13, 2016 Share Posted October 13, 2016 Yes, the same happens here now. mmmm. Sometimes it just drops the symbol, sometimes it creates the plug-in object. Rather erratic then! Quote Link to comment
