jtbrooks Posted October 11, 2016 Share Posted October 11, 2016 Hello, I have created a wall using the wall tool and want to render it using a rendtrworks texture that I have created. Only the top, right and left sides of the wall are accepting the texture, not the front. In the object info pallet, the part selected is overall and the texture is selected. The wall has a solid fill. I have tried giving it no fill, have adjusted the modes and parts to accept the texture. I am not sure what to do to make the front/visible part of the wall accept the texture. I have attached a screen shot to show what I am experiencing. Any and all help is appreciated. Thank you! Quote Link to comment
JBenghiat Posted October 11, 2016 Share Posted October 11, 2016 To get the surface of walls to texture, you have to specify a Right and Left texture. Overall will texture the "guts" of the wall and not the outer surfaces. If you look at a wall in Top / Plan, you can see it has a direction as indicated by the blue arrow near it's start point. This is the direction you originally drew the wall, though you can flip this via object info. If the wall is pointing straight up, the Right texture would be the right surface of the wall and vice versa. By noting your wall direction, you can mentally map right / left to inside / outside. HTH, Josh 1 Quote Link to comment
jtbrooks Posted October 11, 2016 Author Share Posted October 11, 2016 Awesome! Worked immediately. Thank you so much for your help! Quote Link to comment
MichelleA Posted December 6, 2017 Share Posted December 6, 2017 Hi, I am having this issue and "Reversing Side" on the wall does not seem to change anything. Am I flipping the object incorrectly? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 6, 2017 Vectorworks, Inc Employee Share Posted December 6, 2017 2 minutes ago, MichelleA said: Hi, I am having this issue and "Reversing Side" on the wall does not seem to change anything. Am I flipping the object incorrectly? This should cover it in detail:https://www.youtube.com/watch?v=vHBKYfQiwKU Quote Link to comment
