Gytis Posted October 10, 2016 Share Posted October 10, 2016 I am having trouble associating a worksheet with a record format generated by the Detail Bubble tool. I have tried various things to no avail. Attached are screenshots of both worksheet and record. I suspect there is something wrong with the syntax of database headers, since the just generate selves, but don't know. Attached are screen shots. Thanks. Quote Link to comment
Pat Stanford Posted October 10, 2016 Share Posted October 10, 2016 Field and record names that contain spaces must be enclosed in single quotes. Try the following: ='Part Info Record'.'Item #' ='Part Info Record'.'Description' ='Part Info Record'.'Part #' Actually Description does not require quotes because it is a single word, but having the quotes won't hurt and makes using them more consistent. 1 Quote Link to comment
Gytis Posted October 10, 2016 Author Share Posted October 10, 2016 Thanks for that Pat. Unfortunately it only changes the dynamic a little. WS2.tif Quote Link to comment
Gytis Posted October 10, 2016 Author Share Posted October 10, 2016 Well, instead of manually, I used "report" to create the worksheet and all is good. Thanks again Pat. Quote Link to comment
Pat Stanford Posted October 10, 2016 Share Posted October 10, 2016 I didn't read closely enough, just answered the easy part. The part that you really need is creating a database in a worksheet. Right Click on the Row Header (i.e. 2 [I always leave a blank line at the top as it is easier to add a title or anything else I have forgotten that way]) Select Database from the pop out menu. Set the Criteria to Record Detail Bubble Is Present. Now put your formulas in the Database Header Row (i.e. 2, not 2.1, 2.2, etc). The formula will automatically flow down through each of the subrows automatically created for each object that meets the criteria. [I already had this mostly written so decided to finish even though you got what you need] Quote Link to comment
