Converting two points to a vector
Nik
Having trouble getting vectorscript functions that require a vector as parameter to work properly. In the snippet of code below, I think that ang should equal 45°.  But the dialog tells me -90° and then I get the error shown in the attached file:
pt= [1,1]
ang = vs.Vec2Ang(pt)
vs.AlrtDialog(ang)
Edited by Nik
From the developer.Vectorworks.net: If Vect is {0,0,0}, Vec2Ang returns -90.  Your vector input is incorrect, so you are getting the default return value.
Vectors represent three dimensional space, so require three points.  If you are dealing with a plane, just use 0 as the z coordinate.
Also, vectors are represented by a tupple, not an array.  So what you want is:
pt = (1, 1, 0)
-Josh
