AlanW 522 Posted October 5, 2016 This was asked about in another post area so I though I would place it here for other new people. Simple way to create a picture frame with artwork. Marionette-Frame_2_AW_002.vwx 1 Quote Share this post Link to post
fabrica 97 Posted October 5, 2016 would be great if these could be saved as objects to the resource manager, not sure if they can be made into symbols and then 'unboxed' as needed? Quote Share this post Link to post
Patrick Winkler 47 Posted October 5, 2016 2 hours ago, fabrica said: would be great if these could be saved as objects to the resource manager, not sure if they can be made into symbols and then 'unboxed' as needed? Here is a node which should do that : create_sym.vwx Quote Share this post Link to post
AlanW 522 Posted October 5, 2016 @MarissaFHi, An issue with textures still changing. In the attached file if you move the picture around the script must run again and change the textures. Do you see this and if so is there a way to stop this? Thanks Pict_Frame_001.vwx Quote Share this post Link to post
