VerhoevenJ Posted October 3, 2016 Share Posted October 3, 2016 I'm having a problem with marionette. I want to make a series of rectangles. I should be able to first enter how many rectangles I want, then each rectangle should get a different length. Is this possible? Quote Link to comment
Marionette Maven Marissa Farrell Posted October 3, 2016 Marionette Maven Share Posted October 3, 2016 @Jan verhoeven I've attached an example of creating multiple rectangles of different lengths. It would be helpful to also know what you would like to do with these rectangles after. The lengths can be defined however you'd like. In my example, I created a list of lengths with an equal step between them. It is also possible to just attach many dimensions to the "width" port of the rectangle. At the end, I moved the rectangles to show them individually. To use these rectangles outside of the Marionette network, select the resulting group and "ungroup" it. The rectangles will then be independent of the Marionette network. You can also further manipulate the rectangles with Marionette if you would like. mulRects.vwx Quote Link to comment
VerhoevenJ Posted October 3, 2016 Author Share Posted October 3, 2016 (edited) Thanks for the very quick response, Can you send me the VW 2016 files, the dutch version of Vectorworks 2017 is not yet available. The result i want to achieve is not that easy to explain. In the store's we are designing we have to use big refrigerators. These refrigerators exist of diffrent modules, each module has its own tempature, sort of light and a number. I want to create a marionette tool where i can create a series of refrigerators each module in the series will have its own length, temperature indication and other features. I added a preview of what i want to accomplish. In the future i want to add a 3d view Refrigerators.vwx Edited October 3, 2016 by Jan verhoeven Quote Link to comment
Marionette Maven Marissa Farrell Posted October 3, 2016 Marionette Maven Share Posted October 3, 2016 Here's the 2016 file. I'll take a look at your example soon and see how I can help! mulRects_v2016.vwx 1 Quote Link to comment
AlanW Posted October 3, 2016 Share Posted October 3, 2016 @MarissaFHi, in your 2017 script when i move one node it scales up?? Why might this be happening. Quote Link to comment
Marionette Maven Marissa Farrell Posted October 3, 2016 Marionette Maven Share Posted October 3, 2016 It may have to do something with page scale nodes. Some changes have been made with sizing, and sometimes they bounce around a little. We're working on solidifying it! Quote Link to comment
