PVA - Jim
Vision 2017 Release
Today marks the public release of Vision 2017.
Now! This is not a standard update of the Vision software, functionally for users it is nearly identical to Vision 4. The main purpose of this update is to further integrate the Vision product into Vectorworks, while still maintaining the rolling-update system that has traditionally been used throughout Visions release history. More updates and improvements for will of course come, but this update is more about bringing it in line with other products.
If you have a current active subscription for version 4.0 will be able to use Vision 2017 with the same dongle you use currently. Any version of Vectorworks that is compatible with Vision 4 should also be directly compatible with Vision 2017, this update simply lets you take advantages of more of the streamlining features made available in Vectorworks 2017.
Download links for Vision 2017 can be found below:
http://shop.espvision.com/Vision-Demo_c6.htm
You will need to have your dongle plugged in to activate the full version of Vision. If you do not, you will simply be placed in Demo mode until you do. A video covering the simple installation process can be found below:
Does this link work for anyone else? Tried updating on a pc and it seems to have jacked everything up. Both my 4.0 install and 2017 install won't even open anymore.
Thoughts? Tried uninstalls, restarts to no avail.
