alberto72 Posted September 29, 2016 Share Posted September 29, 2016 Hi everybody! Who does know the way to make a linear PIO responsive to Join command ? Thanks. Quote Link to comment
alberto72 Posted September 30, 2016 Author Share Posted September 30, 2016 This is my answer. I create a new command called "Join Linear PIOs", placed under "Edit" menù and this is its code: Procedure JoinTwoSelectedLinearPios; VAR h1,h2:HANDLE; P1,P2,P3,P4:POINT; P:POINT; parallel :BOOLEAN; intOnLines :BOOLEAN; d1,d2,d3,d4:REAL; BEGIN h1:=FSActLayer; h2:=NextSObj(h1); GetSegPt1(h1,P1.x,P1.y); GetSegPt2(h1,P2.x,P2.y); GetSegPt1(h2,P3.x,P3.y); GetSegPt2(h2,P4.x,P4.y); LineLineIntersection(P1,P2,P3,P4,parallel,intOnlines,P); {====gather P1,P2,P3,P4 distances from P========} IF (parallel=FALSE) THEN BEGIN d1:=Distance(P1.x,P1.y,P.x,P.y); d2:=Distance(P2.x,P2.y,P.x,P.y); d3:=Distance(P3.x,P3.y,P.x,P.y); d4:=Distance(P4.x,P4.y,P.x,P.y); { ===== join PIOs trimming the shortest side...=====} IF d1<d2 THEN SetSegPt1(h1,P.x,p.y) ELSE SetSegPt2(h1,P.x,p.y); IF d3<d4 THEN SetSegPt1(h2,P.x,p.y) ELSE SetSegPt2(h2,P.x,p.y); END; END; RUN(JoinTwoSelectedLinearPios); Well, it doesn't check if h1 and h2 are linear PIO's or other objects, but it works with 2d Lines too. Hope to be useful.... Quote Link to comment
