alberto72
Linear PIO behavior
This is my answer. I create a new command called "Join Linear PIOs", placed under "Edit" menù and this is its code:
Procedure JoinTwoSelectedLinearPios;
VAR
h1,h2:HANDLE;
P1,P2,P3,P4:POINT;
P:POINT;
parallel     :BOOLEAN;
intOnLines   :BOOLEAN;
d1,d2,d3,d4:REAL;
BEGIN
h1:=FSActLayer;
h2:=NextSObj(h1);
GetSegPt1(h1,P1.x,P1.y);
GetSegPt2(h1,P2.x,P2.y);
GetSegPt1(h2,P3.x,P3.y);
GetSegPt2(h2,P4.x,P4.y);
LineLineIntersection(P1,P2,P3,P4,parallel,intOnlines,P);
{====gather P1,P2,P3,P4 distances from P========}
    IF (parallel=FALSE) THEN BEGIN
        d1:=Distance(P1.x,P1.y,P.x,P.y);
        d2:=Distance(P2.x,P2.y,P.x,P.y);
        d3:=Distance(P3.x,P3.y,P.x,P.y);
        d4:=Distance(P4.x,P4.y,P.x,P.y);
    {    ===== join PIOs trimming the shortest side...=====}
        IF d1<d2 THEN SetSegPt1(h1,P.x,p.y) ELSE SetSegPt2(h1,P.x,p.y);
        IF d3<d4 THEN SetSegPt1(h2,P.x,p.y) ELSE SetSegPt2(h2,P.x,p.y);
    END;
END;
RUN(JoinTwoSelectedLinearPios);
Well, it doesn't check if h1 and h2 are linear PIO's or other objects, but it works with 2d Lines too.
Hope to be useful....
