Kieran
Applying and editing a texture map in marionette
Hi
I would like to be able to apply a texture to an extrude so that it matches the width of the extrude. Also need to be able to edit the orientation.
I have tried the Set Texture Size node with no luck.
Cheers
Kieran
14 answers to this question
Take a look in Help a the attribute mapping tool.  It will do exactly what you want but the first step can be confusing.
hth
mk
With the current Marionette content, this is very hard/probably impossible to achieve.
There were some changes made for texturing parts in plug-ins, however I haven't had the time to create a proper demonstration of how to do this yet, but those same changes will work on Marionette objects as well. (They will allow you to map textures to the individual parts of your plug-in object, very exciting!)
As soon as I get a working understanding of what the process is and create a tutorial, I will report back here!
12 hours ago, Kieran said:
Hi
Cheers
Kieran
Hi, I have no luck with the Set Texture Size so the only way for me so far is to set the scale in the texture. See attached.Will look further into it. Credit goes to Sean O'Skea for teaching the texture setup.
Textures.vwx
Edited by Alan Woodwell
Hi Alan
Thank you to everyone who responded. Its the first time I have posted and I did not expect a responce.
Attached is the object I have been working on.  Its a frame with an artwork that may be useful to any exhibition designers out there. The frame, glass and matt board are all textured using the Apply Texture node. I had hoped to be able to use a Texture Map node of some sort to control the texture map of the artwork in the frame.  Instead the way forward seems to be to wrap the network, ungroup the each frame the network produces and adjusted the artwork texture map.
I would love any comments on improvements on the network.
Also can anyone tell me where to find the node Ordered Points. I found it in a tutorial but can't find it in the list of nodes definitions.
Cheers
Kieran
Marionette-Frame_2.vwx
@KieranHi, Nice work. It was good for you to learn the process of making the frame the way you did as it will come in handy for may other things.
A fast was is as attached. Create a symbol and extrude it down a path. This can all be put into a Marionette object which I will do later tonight.
HTH
Marionette-Frame_2_AW.vwx
Thank you Alan.
Just downloaded your improved and simplified version and had a play. Love It. Great to learn something new.
Cheers
Kieran
Hi @Alan Woodwell, very good work on Marionette, and thank you for share all the files and you knowledge
I'm trying to apply textures in marionette, but I do not know how to control it.
How can I control the mapping of the texture (Scale, Offset H, Offset V, Rotation, Flip, Repeat)? There is any special node for this?
1500891359_ScreenShot2018-12-02at16_38_27.thumb.png.d8956443917346665a2c0a1b72f1aa85.png
In your Marionette Frame 2, when we start to introduce deferents sizes, the picture do not fit or even rotate in a vertical format.
2101606928_ScreenShot2018-12-02at16_34_38.thumb.png.be7c176aea8cea5b0850c985117adac4.png
Do you have found any solution for this? There are new nodes in the Vectorworks 2019?
Thank you for your help
Hi, will have a look tonight. Pretty sure there are some scale and rotate nodes around.
Hi here are 2 scripts, one for scaling textures (Warning it crashes 2019 everytime i run it)
I would use the other one where it scales a symbol, so make your picture a symbol then scale.
Good Luck
Scaling Symbols-001.vwx
Textures.vwx
