Christian Fekete Posted September 25, 2016 Share Posted September 25, 2016 Why is the model disappearing (except lights) in axon OPENGL ? Quote Link to comment
Christian Fekete Posted September 25, 2016 Author Share Posted September 25, 2016 got it, unified vie was turned off 2 Quote Link to comment
Andrew Davies Posted September 25, 2016 Share Posted September 25, 2016 (edited) Unified view used to kill me all the time. Never really understood it and sometimes it switches off without me knowing. Tried explaining it to a new VWX user the other day - gave up very quickly! I keep all my design layers at 1:1 scale so don't really need it (I don't think) Edited September 25, 2016 by Andrew Davies Quote Link to comment
michaelk Posted September 26, 2016 Share Posted September 26, 2016 Try double clicking on the Unified View button to see the options. By default, turning Unified View off will allow you to see layers that are in scales different from the active layer. If you leave that set and you only work in 2D and all layers are the same scale, then Unified View doesn't matter. The real benefit of turning it on is that when you switch to a new view (Like Top/Plan to Right Iso) it changes all of the design layers to that view. If Unified View is off and you switch views only the active layer switches to the new view. And you can set it to either show screen plane objects in 3d or not show them. Super helpful. There is a default keyboard short cut for it. Command-Option-L or Control-Alt-L. On a Mac, this is close to the connect/combine shortcut. That may be why you're accidentally turning it off. mk Quote Link to comment
