Thomas Wagensommerer Posted September 25, 2016 Share Posted September 25, 2016 (edited) I created this plugin a long time ago. Since it is no longer available from my website I wanted to share it here. Open source of course, because I think there should be more shared content. Framepoly.vso It is a 2D path object that draws a Frame using the undocumented OffsetPoly function. It is compatible with any version of Vectorworks since 2006. It was originally posted there http://www.vectorlab.info/index.php?title=Frame in 2006. Since then I have improved it a little, so it can draw open and closed frames, also the offset can be drawn on either side of the original polygon. Edited September 25, 2016 by Thomas Wagensommerer Quote Link to comment
alberto72 Posted September 30, 2016 Share Posted September 30, 2016 In my Plug-in manager it is seen as a Text file but, I suppose, that is a 2D Path Object. Could you post the parameter list ? Thanks for your sharing...... AB. Quote Link to comment
Thomas Wagensommerer Posted October 5, 2016 Author Share Posted October 5, 2016 Yes it is a path object. In the attachment is Framepoly.vso as a zip file. This should work better. Framepoly.vso.zip Quote Link to comment
