I convert a VW 2016 origin Project to VW 2017.
I cleaned up several secondary Files successfully already.
(Plugin Update, Plugin Reset, Purge)
But the main File where I did the same cleaning procedure at the beginning, I needed to manually
move some Objects to other Layers and delete some Layers used for now unneeded Versions.
After deleting the included Geometry, Purge always crashed.
I deleted the Layers manually but Purge Tool still crashes each time after I accept the 2nd Window.
Has any one else Purge Tool crashing too, with converted VW 2016 Files ?
Is this "Change Layer Bug" related ?
File unfortunately under NDA.
But full low privacy extended crash details and usage patterns delivery activated.
