The Incandescent Fixture tool needs a big overhaul - it should be the Lighting Fixture tool and should have the following capabilities:
1) Both Default + Custom 2D + 3D geometry.
2) Type (Style) control. So that I can select the fixture and select C4 from my list and have it update to the project type of C4.
3) Wattage Info for scheduling and energy Calcs
4) Built in ability to be lighting elements for Renders (Ability to turn on and off individually or by circuit.
5) Ability to be flush mounted in Slab objects without having to cut the slab (the same way doors work in walls).
6) Story aware placement.
7)Ability to connect lights into circuits and assign those circuits to switch locations in an intelligent way. (ie - select the ligth switch and have all lights controlled by the switch highlight)
Tom Klaber
6 answers to this question
