Kevin McAllister 1,044 Posted September 21, 2016 There seems to be some sort of selection/snap highlighting issue with Camera based SLVP in VW2017. I've been seeing it in files I've brought forward and I am able to duplicate it in a clean file built in VW2017. What I'm seeing is the dashed grey highlight lines are often offset from the geometry they are highlighting. In the attached file it occurs as per this image and also when you mouse over the hidden crop object. The offset seems to vary depending upon where the viewport is on the sheet. As far as I can tell it only happens with Camera based (or maybe perspective based) viewports. Kevin Highlighting Issue.vwx 1 Quote Share this post Link to post
Matt Panzer 421 Posted September 22, 2016 Hi Kevin, Thanks for bringing this to our attention! I looked into this and see that it is a known issue. A bug report has already been filed on this. Hopefully this will be resolved soon. Quote Share this post Link to post
Kevin McAllister 1,044 Posted September 22, 2016 Thanks Matt! Kevin Quote Share this post Link to post
Christian Fekete 12 Posted September 28, 2016 i have had issues with ghost images showing up after deletion. It seems that there are many issues related to screen refreshing. I seem to have resolved my issue by lowering the Navigation graphics from Best to the lower option good performance and compatibility. Quote Share this post Link to post
Kevin McAllister 1,044 Posted May 27, 2017 (edited) Is there any movement on this highlighting issue? I thought it would be fixed by now. I'm finding it happens with all sorts of sheet layer viewports, not just perspective viewports as I originally noted. Kevin Edited May 27, 2017 by Kevin McAllister 1 Quote Share this post Link to post
Andy Broomell 691 Posted May 27, 2017 Seeing it here often as well. Quote Share this post Link to post
rDesign 325 Posted May 27, 2017 On 9/22/2016 at 5:44 AM, Matt Panzer said: Hi Kevin, Thanks for bringing this to our attention! I looked into this and see that it is a known issue. A bug report has already been filed on this. Hopefully this will be resolved soon. 8 months later and still no fix. It's frustrating that, just this week Vw sent me an email announcing the increased cost of VSS subscriptions for Vw2018 upgrades, while we are still dealing with bugs like this that have yet to be fixed in Vw2017. Can anyone reliably use the 'Best' performance option? I am going to be very disappointed if Vw2018 is released and we still have all of these widespread graphic refresh / ghosting / performance issues. Quote Share this post Link to post
markdd 468 Posted May 28, 2017 I see a very similar occurrence of it when using the space navigator in Open GL design layers. Quote Share this post Link to post
Kevin McAllister 1,044 Posted May 28, 2017 It seems to be directly related to the VW Preference>Interactive>Snapped Object Highlighting.... Kevin Quote Share this post Link to post
Kevin McAllister 1,044 Posted September 21, 2017 (edited) This highlighting issue remains in VW2018. Do I need to refile it as a bug? Kevin Edited September 21, 2017 by Kevin McAllister Quote Share this post Link to post
Matt Panzer 421 Posted September 21, 2017 45 minutes ago, Kevin McAllister said: This highlighting issue remains in VW2018. Do I need to refile it as a bug? Hi Kevin, I believe this is a known issue. If you previously submitted a bug on this and it was not resolved, I suggest adding a comment to that bug stating the it's still an issue. Otherwise go ahead and submit a new report. This needs to be fixed. Thanks! -Matt Quote Share this post Link to post
Kevin McAllister 1,044 Posted September 21, 2017 19 minutes ago, Matt Panzer said: Hi Kevin, I believe this is a known issue. If you previously submitted a bug on this and it was not resolved, I suggest adding a comment to that bug stating the it's still an issue. Otherwise go ahead and submit a new report. This needs to be fixed. Thanks! -Matt Thanks Matt. I didn't submit it originally because you said it was a known issue (towards the top of the thread). I think I will submit it now. Its very specific - the sheet layer viewport needs to be in perspective, camera based and its only the foreground objects that have their highlighting offset - hidden line rendering, crops, things in annotations. Kevin Quote Share this post Link to post
Matt Panzer 421 Posted September 21, 2017 Ok, great. Thanks Kevin. I do still see an open bug similar to this but it certainly helps to have your report as well - in case it's something slightly different. It also allows you to keep an eye on the issue. :-) Thanks! -Matt Quote Share this post Link to post
Kevin McAllister 1,044 Posted September 21, 2017 7 minutes ago, Matt Panzer said: Ok, great. Thanks Kevin. I do still see an open bug similar to this but it certainly helps to have your report as well - in case it's something slightly different. Submitted! 8 minutes ago, Matt Panzer said: It also allows you to keep an eye on the issue. :-) I think maybe you know something I don't. As far as I'm aware there's currently no public tracking method for bug submissions Kevin Quote Share this post Link to post
Matt Panzer 421 Posted September 22, 2017 Err... oops! I think you're right. Forget I said that. ;-P Thank you for submitting! -Matt 1 Quote Share this post Link to post
Kevin McAllister 1,044 Posted January 26, 2018 Is there any updated news on this issue? I'm working on some complex drawings and the offset selection highlighting really is in the way. Its time this bug was squashed. Kevin Quote Share this post Link to post
Matt Panzer 421 Posted January 26, 2018 @Kevin McAllister, Do you have the bug number on this? Quote Share this post Link to post
Kevin McAllister 1,044 Posted January 26, 2018 (edited) 1 hour ago, Matt Panzer said: @Kevin McAllister, Do you have the bug number on this? Nope. Only you have access to the secret system.... we in the outside world are still in the dark :-) Should I refile it again? Kevin Edited January 26, 2018 by Kevin McAllister Quote Share this post Link to post
Matt Panzer 421 Posted January 28, 2018 No need to report it again. I found a few reports already. I agree that this needs to be fixed. I nudged the report to see if it can be dealt with soon. Quote Share this post Link to post
Kevin McAllister 1,044 Posted January 28, 2018 Thanks Matt. Much appreciated! Kevin Quote Share this post Link to post
Kevin McAllister 1,044 Posted November 6, 2018 This is still present in VW2019. Initially I thought it was fixed and it seems to be for mousing over camera linked viewports on a sheet layer. But if you edit the annotations of those viewports the offset highlighting issue still remains. Kevin 1 Quote Share this post Link to post
