Jordan Grimes Posted September 21, 2016 Share Posted September 21, 2016 (edited) I have 3 light pipes each with 9 fixtures. When I select all fixtures and turn on light only 8 beams show at a time. (every configuration is always only 8 visible at a time...all show as on thought) If i then go to a single fixture and turn it off a beam that visible will appear on another fixture...usually a differ pipe. I have even deleted all fixtures and put the back into the drawing. Same thing happens every time. Here is what happens with select all fixture and turn light on... Here is what happens when I manually turn on 8 lights, after 8 the system will start hiding beams for every light I turn on. Edited September 21, 2016 by JordanG Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 21, 2016 Vectorworks, Inc Employee Share Posted September 21, 2016 OpenGL is limited to 8 light sources at a time. To see more than that, you will need to use one of the Renderworks rendering modes. 1 Quote Link to comment
Jordan Grimes Posted September 22, 2016 Author Share Posted September 22, 2016 Thanks so much. I was wondering what the heck was going on. Ill use Renderworks. Quote Link to comment
