Plant Record "Symbol" - How do I edit?
uglycat
Hi all,
I am now trying to use the built in plant database and plant record system. I have created a lot of plants and everything seems to work well. I have one plant that shows on my planting schedule worksheet under column =('Plant Record'.'Symbol') with the wrong "Symbol", the only place I can see to change it is under the plant ID but when I do that it has no effect. I see no place to change the plant record "symbol". Any ideas? If I select the symbol and look in the object info data tab it shows under plant record (read only) , its the first line but I see no place I can edit that. I understand I can pull the plant ID instead of =('Plant Record'.'Symbol') but want to know why this doesn't work. Thanks.
0 answers to this question
