1.
I think it needs a way to export Story and Level settings from one File to the other.
And in current state, an Error Message when you try to send Story/Level bound Objects into another File,
that this will not work.
2.
Default Level should keep Linking.
I think it is not good when you do changes and end up with lots of duplicates of Levels with same name,
that will only disappear when you activated the current ones manually for each story,
if you can ever keep overview.
3.
Also I do not understand the Default Levels Naming hidden under Layer Organisation while in Story Settings
you can edit their Z Values only.
1.
2.
3.
Edited by zoomerAlso I do not understand the Default Levels Naming hidden under Layer Organisation while in Story Settings
