markdd
Spotlight Instrument Y rotation broken in 2017
Has the Y rotation of the Spotlight Instrument Tool  been changed? It now rotates the instrument around the Z axis which is surely what the instrument rotation field is for. This could actually be a really useful addition but could it be labelled Z rotation and please put back the Y rotation to the way it has been working for a few years now. Apart from anything else, this makes the "Create Plot and Model" command far less useful. This is bad news for me if this is seen as an improvement not least because drawings created using it do not display correctly in 2017 and will need to be opened in earlier versions of the software which I am sure is not the point of the annual upgrade.
As you can see from the attached file, when drawing a boom of lights it is often desirable to draw them at an angle (say 30°) so that the labels display clearly and the fixtures don't overlap in 2D and it was always possible to adjust the X and Y axis to bring the fixture back to a true hanging orientation like the example on Boom-1. This is now impossible because of this new bug. I would be grateful if this can be fixed.
Many thanks
Untitled_1.vwx
Edited by markdd
edit
16 answers to this question
Thanks Jim
I don't see how it can be working "as designed" when it is working differently to the way it has done in all the versions of the software since the feature was introduced! I have used the feature extensively for a few years now. Maybe they should check again!!?
I will submit a bug report over the weekend.
Mark
Apologies, I mean they changed it intentionally but immediately got reports like yours, so are rethinking.
I'd be very interested to hear the explanation of how the new way is "as designed". The Y Rotation has worked predictably the same since Lighting Device 3D Orientation was introduced (I believe with VW 2008, so 9 years/versions now).
As Mark said, Device Rotation and Y Rotation control exactly the same thing now. Rotation rotates around the Z axis, X rotates around X, and Y now rotates around Z instead of Y?
No clue what the thinking was there. But this isn't my area of expertise unfortunately, a lot of this I channel directly to the engineers for review.
Jim
pethaps one of your engineers could chip in from time to time with answers to Spotlight specific queries/frustrations as I don't know about other Spotlight users, but it seems that we are not always as well served as other disciplines on this forum. (There, I said it!)
Thanks
Mark
That's the master plan! You will start to see more of that as time goes on I think. The Cloud and Webview teams will probably be first just due to the nature of their structures, but I hope to become redundant as the pros visit the forums more and more often. I know a little about a lot but my ignorance really starts to show in the more advanced and/or industry specific topics like Lighting Design, BIM, IFC, Site Design, etc and I hope our professionals here can be used to supplement my limited ability.
Thanks for that. There used to be a spotlight moderator called Kevin who was very helpful, but I haven't heard from him recently.
Many thanks
Mark
That would be @klinzey! He's the go-to spotlight guy. I may try twisting his arm (and/or bribing him) to come around more often.
I just found this "design feature"  The tech support people say the engineers changed it and that it is part of other changes.  The work around he gave me to have a sideways raked fixture is to rotate the body 90 from the rotation in the OIP, then to do a Y rotate in the 3d rotation box at the bottom of the OIP.  the problem with this is that the fixture is no 90 deg off from the truss or pipe and with no focus points the fixtures look funny from front views.
