I would like to see the ability to change units within a viewport that would be different from the global unit settings within a file.
For instance, If I had my drawing file set to imperial, but had a site survey that was in metric, and I wished to maintain that site plan in metric, but leave the rest of my drawing file in imperial, I could change the site plan viewport to metric and dimension in the preferred units, such as in meters.
Another override within a viewport that some what falls in line with this request is to have an independent dimension style. In some cases, for clarity, the above site plan may need to have dual dimensions of metric and imperial. In an example, I would like to have the metric dimension shown in meters with an imperial dimension in decimal feet. e.g.. 60m (196.85') vs having it read 60m (196'-10 1/8"). Then in the rest of the file if dual dimensions were required they could be metric mm and feet and inches. 3048mm (10'-0")
rgcn
Rob
3 answers to this question
