jtbrooks Posted September 15, 2016 Share Posted September 15, 2016 (edited) Hello, I have used the Soft Goods tool to make curtains. I want to change the color of the curtains from standard black to a pearlescent fabric texture that I have created as new Rendtrworks texture. No matter what I do, the curtains will not take the texture and remain black. I have tried everything I can think of in the OIP, Attributes and Class. What should I do? Thanks! Edited September 15, 2016 by jtbrooks 1 Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 16, 2016 Vectorworks, Inc Employee Share Posted September 16, 2016 Could you please post the soft good and texture in an example file and post it? I can take a closer look. Quote Link to comment
jtbrooks Posted September 16, 2016 Author Share Posted September 16, 2016 Yes, I have copied and pasted the soft goods into the attached file. Thank you! Soft Goods.vwx Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 16, 2016 Vectorworks, Inc Employee Share Posted September 16, 2016 Ahh, I forgot Soft Goods work oddly: Select the Soft Good, then in the Shape tab of the Object Info palette, click "3D Curtain Options", then, from the menu on the top, select Custom. Under Custom you should then be able to pick the texture you want. Quote Link to comment
C. Andrew Dunning Posted September 16, 2016 Share Posted September 16, 2016 (edited) 5 hours ago, jtbrooks said: I have used the Soft Goods tool to make curtains. I want to change the color of the curtains from standard black to a pearlescent fabric texture that I have created as new Rendtrworks texture. No matter what I do, the curtains will not take the texture and remain black. I have tried everything I can think of in the OIP, Attributes and Class. What should I do? If you're running 2017 (or a recent version of the Landru Design version, SoftGoofds 2), click on the "3D Curtain Options" button in the OIP. Choose the "Custom" option. You'll them be able to choose Textures from either your current file or from VW files found in "...\Libraries\Defaults\Soft Goods - Custom Textures." I hope that helps. Edited September 16, 2016 by C. Andrew Dunning 2 Quote Link to comment
jtbrooks Posted September 16, 2016 Author Share Posted September 16, 2016 It worked! Thank you very much for your help! 1 Quote Link to comment
