Assign to layer BUG
EAlexander
I can crash VW2017 on my system every time by moving and object from one layer to another via the OIP.  This is happening with 3D objects in files picked up from 2016.
To test, I made a new 2017 document, made two layers, drew a rectangle on one, and when I change it's layer via OIP, instant crash.  So what exactly is the best way to report this with system and OS specs to tech?
Thanks,
e.
This is a known issue and I was given a fix by a member of VW support staff. Basically it's a plugin that gets corrupted on installation that needs to be re pasted into the plugins folder.
Perhaps you should contact him directly JAlmansa@vectorworks.net or message me directly and I'll forward his email to you which explains the fix. (not sure it's good practice to just paste the email here?)
Looks to have been a problem happening during installation, a plugin becomes corrupt with a particular combination of OS and serial number type which explains why it didn't get caught in testing. I do not have the files need (I'll see about getting them for public posting to make this quicker) but contact tech@vectorworks.net and we will get you sorted out.
A fix for this will ALSO be in an upcoming service pack but we can get everyone having problems handled right away, there is no need to wait.
3 minutes ago, crosetti said:
Hello,
In 2017, Moving any object to another layer via object info palette crashes VW 2017 every time ... EVERY time.
Is this a known issue or specific to me? Any Fixes?
Thanks!
Merged into main thread, Tech@vectorworks.net should be able to get you sorted out.
1 minute ago, sparky said:
When I edit a viewport properties from the Navigation Pallet to change the sheet layer a VP is on, VW crashes.  This is with my template file I brought in from 2016.  Anyone else seeing this?
Merged into main thread, this will be patched, but you can contact Tech Support directly and they can get you sorted out in the meantime.
2 hours ago, Mike Wright said:
couldn't find a bug submission area so here's my problem
When changing the layer of an Audio Tools speaker array the program crashes
Windows 10 64Bit
Merged into main thread, Tech Support should be able to get you squared away.
