assemblyarchitecture
why do cameras keep shifting
I have reset the cameras countless of times. Setting up consistent renderings to place into photo montages takes a while and the camera's z setting will often go haywire moiving hundreds of feet vertically or shifting off horizontally. I don't know what's going on, if I should put down a locus to reset the camera, but that defeats the purpose of having a camera set up in the first place. I notice when the camera palate is open and the camera is selected, there seems to be a glitch in that the corrupted camera will stay selected even though a different camera is active. Has this happened to anyone else. It happened in multiple files for different projects so I think there's a glitch somewhere
mac 10.10.5/VW2016 sp4
Edited by assemblyarchitecture
system
That is all well known.
Plus some other issues like auto adding the old viewport crop setting and those things.
It got worse with the last Service Pack when Cameras, like a saved view, contain Layer Visibilities,
or at least preserve to make their own Layer the active Layer, while doing visibility changes seems
to further corrupt the Cameras.
I don't know why and how that could happen and stay for a whole software release.
Let's cross fingers for VW 2017 release.
Edited by zoomer
You need to disable the camera when entering the viewport as I understand it e viewport is the lense of the camera and as soon as you move you take the camera with you.
I haven't linked a camera to a viewport since that seemed problematic based on some previous posts. I have just been exporting images from the camera on a design later, but that's helpful. Maybe I have been dragging the camera when rotating the model. Can you lock a camera? if not it would probably be a good feature. It happened again since posting so I may start writing down the coordinates for the camera.
If you create a viewport from the camera when you go in through the viewport dont have camera ticked on the viewport.
HTH
Alan, we use Cameras just like other plugin objects.
For Example to exchange with C4D. So they can't be hidden in a viewport.
VW 2017 :
Cameras aren't any better, at least those from converted 2016 Files.
They lose their coordinates even more likely.
Nearly useless at the moment.
