1. Drag :
Please change the way it works so that it is possible to add a numeric value "after" you left your left mouse button.
So the tool stays active after a Drag operation to accept numerical distance input - depending on drag/cursor direction !
That it is no more necessary to start input Numbers BEFORE you can leave the mouse button.
(Left Hands stays to do shortcuts, only Right Hand switches between Mouse and Num Block numerical entries)
Like :
Click and hold LMB > Drag to RIGHT > release LMB > Num Block : "10,62" => Drag Distance X = 10,62 working units
or
Click and hold LMB > Drag to LEFT > release LMB > Num Block : "10,62" => Drag Distance X = minus 10,62 working units
or
Click and hold LMB > Drag to TOP > release LMB > Num Block : "10,62" => Drag Distance Y = 10,62 working units
or
Click and hold LMB > Drag to BOTTOM > release LMB > Num Block : "10,62" => Drag Distance Y = minus 10,62 working units
So including cursor direction recognition. (In general for all Tools !)
If there will not follow any numerical input and instead you do a mouse click to select or drag again it will behave as normally.
zoomer
1. Drag :
Like :
or
or
or
4 answers to this question
