ga Posted July 30, 2003 Share Posted July 30, 2003 encountered this error when trying to export to dwg. can anyone tell me what the problem is? 'internal error encountered. cannot continue' ga Quote Link to comment
Guest Posted July 30, 2003 Share Posted July 30, 2003 What version of VW are you using? Quote Link to comment
ga Posted July 30, 2003 Author Share Posted July 30, 2003 we are on VW9.5.3 and OS10.2.1 it only effects some files, not all. the only quick solution i have found is to cut and paste the file into a file that does export. this is not viable though as it takes too long. ga Quote Link to comment
Guest Posted July 30, 2003 Share Posted July 30, 2003 Try to export the file to a different location, or change the name of the filename you are choosing for the exported file. You may need to shorten the name. Quote Link to comment
ga Posted July 30, 2003 Author Share Posted July 30, 2003 thats not the answer i'm afraid. both of these had no effect any other suggestions? Quote Link to comment
Guest Posted July 30, 2003 Share Posted July 30, 2003 You can email the file to me and I can try to figure out why it's not working. Click to email me Quote Link to comment
kshick Posted March 16, 2004 Share Posted March 16, 2004 Was there any resolution to this internal error problem? I am periodically encountering the same thing with VW 9.5.3 and OSX 10.2.8. There is no consistantancy to when or what file it happens to. Quote Link to comment
Guest Posted March 16, 2004 Share Posted March 16, 2004 I can't remember back that long ago on the resolution of the problem. I suggest you contact Tech Support at tech@nemetschek.net or 410-290-5114 for more assistance. They will be able to look up in the TS database what my resolution to the problem was. Quote Link to comment
