Kevin McAllister Posted September 8, 2016 Share Posted September 8, 2016 I'm curious to know if its possible to display values generated by a Marionette network in the OIP. I've experimented a little with the Marionette OIP controls and I am able to display static info using Marionette.WidgetType.TextStaticParam. I've created a couple of simple custom nodes for Maker Info and Object Name and I'm able to essentially trick Marionette into displaying this info for Marionette Objects (image below). But what if I wanted to display the area of an object generated by a Marionette Object in a static manner like what you see with a regular VW object. Is this possible? Is there a way to feed a variable from a network back to the OIP? I know I can easily display something like this as text on the drawing but I'd like it in the OIP. Thanks, Kevin OIP Example.vwx Quote Link to comment
willofmaine Posted September 8, 2016 Share Posted September 8, 2016 I don't think so... In this thread ( forum.vectorworks.net/index.php?/topic/43428-marionette-objects-and-oip/ ) I'd asked: "OIP Display: In my script, there's a mathematical calculation, the results of which I want displayed in the OIP. How do I do that? I can't seem to find the right kind of node" and Marissa responded: "OIP Display: Not currently possible. We can't even programmatically define values at all in the OIP, really. At least not the way we would need to in this case." Quote Link to comment
Marionette Maven Marissa Farrell Posted September 8, 2016 Marionette Maven Share Posted September 8, 2016 I still stand by what Will quoted. It's being looked into, but I don't think enough progress has been made to say it's coming any time soon. Basically, the issue is that the OIP fields are only generated when you edit a script, not when you run it, since they're defined in the Params class. We can't push information there to update when the script runs at this time. I don't know what kind of backend work would have to go into it. Quote Link to comment
Kevin McAllister Posted September 8, 2016 Author Share Posted September 8, 2016 That's what I suspected. Everything pointed to the OIP being used for gathering information rather than displaying it. Off to the wishlist.... Kevin Quote Link to comment
the frog Posted September 12, 2016 Share Posted September 12, 2016 hello You can display info in the OIP data if you build a data base. If you change the value it will change the drawing. This is the purpose of the "rail script". Have a look rail script.vwx Quote Link to comment
