Andrew Mac Posted September 7, 2016 Share Posted September 7, 2016 Is it possible to paste in place between annotations and the design layer? Quote Link to comment
Tom Klaber Posted September 7, 2016 Share Posted September 7, 2016 Yes....sort of. The location of annotations is not relative to the objects inside the viewport - but seems relative to the 0,0 of the sheet layer and the 0,0 of the design layer. So if you create a viewport and then do not move it from its automatic positioning in the sheet layer - then the annotation will paste place correctly - since you have not changed the relative position, but if you move the viewport to the center of the sheet layer for example, then the annotation will not paste back correctly. Quote Link to comment
