Dscape
Window crash glitch sinnce project share conversion 2016
We are having trouble in a project share file. Vectorworks crashes when you try to click into the settings or double click on any window within the model. This even happens to windows that have just been created. Do you have any suggestions as to how to fix this?  We are currently working in VW2016 SP3
4 answers to this question
For me once helped to do :
Tools > Utilities > Reset All Plugins
For an imported door.
I think the problem was deleting their Classes with the "assign objects to other existing Class" Option.
Even after deleting that door from file it instantly crashed when trying to open door settings dialog,
until I did that plugin reset. (+ "convert old plugins from 2012" etc.)
This ^
Also, make sure to update all of your workstations to SP4 as soon as you have the time. Link is available in my signature.
19 hours ago, JimW said:
This ^
I ran the Reset All Plugins and Update and it hasn't helped and we are all running SP4, I mistyped.
I have also:
Purged the file – using the tool but also manually
Made sure the most recent service pack is installed
Converted the file back into a normal file by saving a copy out
Copied all the model data from all layers/classes into a new file – the windows are perfectly fine
Deleted all worksheets within the file (window schedules etc) – no change
Checked that there is no glitched geometry far from the origin
The origin is not really far away
Deleted all window elements and then created a new window
Tried the file on other computers for other users and with the same result
The issue is still occuring.  Any other ideas?
