I posted this on the old forum, but it seems to have disappeared.
I'm running VW2016 SP4 on OS X 10.11.6 with Architect and RW.
I've got a brand new 27" iMac, and now (it worked perfectly on my old computer, with exactly the same software) whenever I run solar animations, it renders two frames and then gives up without an error. This happens even on a brand new file, with only a helidon object in it. I've reinstalled VW and the same behaviour occurs.
Any ideas?
Console prints out a bunch of stuff that seems relevant when I try to run one:
31/08/16 10:13:03.706 AM QuickLookSatellite[419]: [10:13:03.706] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305
31/08/16 10:13:03.706 AM QuickLookSatellite[419]: [10:13:03.706] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/Wellington%20March%2020.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893
31/08/16 10:13:03.706 AM QuickLookSatellite[419]: [10:13:03.706] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157
31/08/16 10:13:03.708 AM QuickLookSatellite[419]: [10:13:03.708] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305
31/08/16 10:13:03.708 AM QuickLookSatellite[419]: [10:13:03.708] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/u.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893
31/08/16 10:13:03.708 AM QuickLookSatellite[419]: [10:13:03.708] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157
31/08/16 10:13:03.709 AM taskgated[374]: no application identifier provided, can't use provisioning profiles [pid=956]
31/08/16 10:13:03.754 AM garcon[956]: Failed to connect (colorGridView) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
31/08/16 10:13:03.754 AM garcon[956]: Failed to connect (view) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
31/08/16 10:13:03.764 AM appleeventsd[49]: <rdar://problem/11489077> A sandboxed application with pid 956, "Dropbox Finder Integration" checked in with appleeventsd, but its code signature could not be read and validated by appleeventsd, and so it cannot receive AppleEvents targeted by name, bundle id, or signature. Install the application in /Applications/ or some other world readable location to resolve this issue. Error=ERROR: #100013 { "NSDescription"="SecCodeCopySigningInformation() returned 100013, -." } (handleMessage()/appleEventsD.cp #2098) com.apple.root.default-qos
31/08/16 10:13:03.876 AM QuickLookSatellite[419]: [10:13:03.876] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305
31/08/16 10:13:03.876 AM QuickLookSatellite[419]: [10:13:03.876] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/u.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893
31/08/16 10:13:03.876 AM QuickLookSatellite[419]: [10:13:03.876] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157
31/08/16 10:13:03.939 AM garcon[956]: Connecting to Dropbox on 'com.getdropbox.dropbox.garcon.cafe_503'
31/08/16 10:13:03.940 AM garcon[956]: Connected to Dropbox on 'com.getdropbox.dropbox.garcon.cafe_503'.
31/08/16 10:13:03.940 AM garcon[956]: Garcon is ready (1 alive).
31/08/16 10:13:03.940 AM garcon[956]: Invalidating watch set.
31/08/16 10:13:03.947 AM garcon[956]: Watch set is now: {(
file:///Users/three/Team%20Dropbox%20(new),
file:///Users/three/Dropbox/
31/08/16 10:13:12.531 AM Vectorworks[601]: GVA info: preferred scaler idx 1
31/08/16 10:13:12.536 AM Vectorworks[601]: AVF error: Perf capability check failed: 0xe00002be
31/08/16 10:13:13.161 AM Vectorworks[601]: <<<< VT-CS >>>> vtCompressionSessionCompressionWork: vtCompressionSessionEncodeWork -12348
31/08/16 10:13:13.162 AM Vectorworks[601]: [10:13:13.161] <<<< MediaProcessor >>>> mediaprocessor_OutputSampleBuffer: (0x7fd0bbefab40) processing failed (-12348), posting notification and continuing
31/08/16 10:13:13.535 AM mdworker[762]: [10:13:13.534] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305
31/08/16 10:13:13.535 AM mdworker[762]: [10:13:13.535] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/eou.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893
31/08/16 10:13:13.535 AM mdworker[762]: [10:13:13.535] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157
31/08/16 10:13:13.540 AM Vectorworks[601]: [10:13:13.540] FigMediaProcessorGetSampleBufferProcessor signalled err=-12785 (kCMBaseObjectError_Invalidated) (FigMediaProcessor was invalidated) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/MediaConverter/FigMediaProcessor.c line 771
31/08/16 10:13:13.541 AM Vectorworks[601]: [10:13:13.541] VTCompressionSessionGetPixelBufferPool signalled err=-12903 (kVTInvalidSessionErr) (Session was invalidated) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/VideoToolbox/VTCompressionSession.c line 2350
31/08/16 10:13:13.647 AM Vectorworks[601]: [10:13:13.647] assetWriter_AddPixelBuffer signalled err=-12348 (storage->failureError) (AssetWriter has posted a failure notification) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/Export/FigAssetWriter.c line 1355
31/08/16 10:13:13.647 AM Vectorworks[601]: writeNSImageAsFrame error Error Domain=AVFoundationErrorDomain Code=-11800 "The operation could not be completed" UserInfo={NSUnderlyingError=0x7fd0bbbf8c80 {Error Domain=NSOSStatusErrorDomain Code=-12348 "(null)"}, NSLocalizedFailureReason=An unknown error occurred (-12348), NSLocalizedDescription=The operation could not be completed},{
NSLocalizedDescription = "The operation could not be completed";
NSLocalizedFailureReason = "An unknown error occurred (-12348)";
NSUnderlyingError = "Error Domain=NSOSStatusErrorDomain Code=-12348 \"(null)\"";
31/08/16 10:13:13.735 AM QuickLookSatellite[419]: [10:13:13.735] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305
31/08/16 10:13:13.735 AM QuickLookSatellite[419]: [10:13:13.735] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/eou.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893
31/08/16 10:13:13.735 AM QuickLookSatellite[419]: [10:13:13.735] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157
31/08/16 10:13:13.877 AM garcon[956]: Garcon destroyed (0 alive).
31/08/16 10:13:13.878 AM garcon[956]: host connection <NSXPCConnection: 0x7fc5196403d0> connection from pid 601 invalidated
31/08/16 10:13:14.236 AM Vectorworks[601]: [10:13:14.236] <<<< RemoteEncode - client >>>> vtRemoteEncoderWaitForPendingFramesToComplete: Encoder didn't emit all frames during Invalidate. cancelling them.
31/08/16 10:13:14.236 AM Vectorworks[601]: [10:13:14.236] vtCompressionSessionTrackFrameGetInfo signalled err=-12902 (kVTParameterErr) (Unrecognised VTVideoEncoderFrame token passed in by encoder) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/VideoToolbox/VTCompressionSession.c line 2301
31/08/16 10:13:15.252 AM mdworker[762]: [10:13:15.252] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305
31/08/16 10:13:15.253 AM mdworker[762]: [10:13:15.253] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/eou.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893
31/08/16 10:13:15.253 AM mdworker[762]: [10:13:15.253] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157
yomcat
Any ideas?
31/08/16 10:13:03.706 AM QuickLookSatellite[419]: [10:13:03.706] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:03.706 AM QuickLookSatellite[419]: [10:13:03.706] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:03.706 AM QuickLookSatellite[419]: [10:13:03.706] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/Wellington%20March%2020.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893 31/08/16 10:13:03.706 AM QuickLookSatellite[419]: [10:13:03.706] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157 31/08/16 10:13:03.708 AM QuickLookSatellite[419]: [10:13:03.708] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:03.708 AM QuickLookSatellite[419]: [10:13:03.708] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:03.708 AM QuickLookSatellite[419]: [10:13:03.708] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/u.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893 31/08/16 10:13:03.708 AM QuickLookSatellite[419]: [10:13:03.708] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157 31/08/16 10:13:03.709 AM taskgated[374]: no application identifier provided, can't use provisioning profiles [pid=956] 31/08/16 10:13:03.754 AM garcon[956]: Failed to connect (colorGridView) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable 31/08/16 10:13:03.754 AM garcon[956]: Failed to connect (view) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable 31/08/16 10:13:03.764 AM appleeventsd[49]: <rdar://problem/11489077> A sandboxed application with pid 956, "Dropbox Finder Integration" checked in with appleeventsd, but its code signature could not be read and validated by appleeventsd, and so it cannot receive AppleEvents targeted by name, bundle id, or signature. Install the application in /Applications/ or some other world readable location to resolve this issue. Error=ERROR: #100013 { "NSDescription"="SecCodeCopySigningInformation() returned 100013, -." } (handleMessage()/appleEventsD.cp #2098) com.apple.root.default-qos 31/08/16 10:13:03.876 AM QuickLookSatellite[419]: [10:13:03.876] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:03.876 AM QuickLookSatellite[419]: [10:13:03.876] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:03.876 AM QuickLookSatellite[419]: [10:13:03.876] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/u.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893 31/08/16 10:13:03.876 AM QuickLookSatellite[419]: [10:13:03.876] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157 31/08/16 10:13:03.939 AM garcon[956]: Connecting to Dropbox on 'com.getdropbox.dropbox.garcon.cafe_503' 31/08/16 10:13:03.940 AM garcon[956]: Connected to Dropbox on 'com.getdropbox.dropbox.garcon.cafe_503'. 31/08/16 10:13:03.940 AM garcon[956]: Garcon is ready (1 alive). 31/08/16 10:13:03.940 AM garcon[956]: Invalidating watch set. 31/08/16 10:13:03.947 AM garcon[956]: Watch set is now: {( file:///Users/three/Team%20Dropbox%20(new), file:///Users/three/Dropbox/ )}. 31/08/16 10:13:12.531 AM Vectorworks[601]: GVA info: preferred scaler idx 1 31/08/16 10:13:12.536 AM Vectorworks[601]: AVF error: Perf capability check failed: 0xe00002be 31/08/16 10:13:13.161 AM Vectorworks[601]: <<<< VT-CS >>>> vtCompressionSessionCompressionWork: vtCompressionSessionEncodeWork -12348 31/08/16 10:13:13.162 AM Vectorworks[601]: [10:13:13.161] <<<< MediaProcessor >>>> mediaprocessor_OutputSampleBuffer: (0x7fd0bbefab40) processing failed (-12348), posting notification and continuing 31/08/16 10:13:13.535 AM mdworker[762]: [10:13:13.534] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:13.535 AM mdworker[762]: [10:13:13.535] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/eou.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893 31/08/16 10:13:13.535 AM mdworker[762]: [10:13:13.535] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157 31/08/16 10:13:13.540 AM Vectorworks[601]: [10:13:13.540] FigMediaProcessorGetSampleBufferProcessor signalled err=-12785 (kCMBaseObjectError_Invalidated) (FigMediaProcessor was invalidated) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/MediaConverter/FigMediaProcessor.c line 771 31/08/16 10:13:13.541 AM Vectorworks[601]: [10:13:13.541] VTCompressionSessionGetPixelBufferPool signalled err=-12903 (kVTInvalidSessionErr) (Session was invalidated) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/VideoToolbox/VTCompressionSession.c line 2350 31/08/16 10:13:13.647 AM Vectorworks[601]: [10:13:13.647] assetWriter_AddPixelBuffer signalled err=-12348 (storage->failureError) (AssetWriter has posted a failure notification) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/Export/FigAssetWriter.c line 1355 31/08/16 10:13:13.647 AM Vectorworks[601]: writeNSImageAsFrame error Error Domain=AVFoundationErrorDomain Code=-11800 "The operation could not be completed" UserInfo={NSUnderlyingError=0x7fd0bbbf8c80 {Error Domain=NSOSStatusErrorDomain Code=-12348 "(null)"}, NSLocalizedFailureReason=An unknown error occurred (-12348), NSLocalizedDescription=The operation could not be completed},{ NSLocalizedDescription = "The operation could not be completed"; NSLocalizedFailureReason = "An unknown error occurred (-12348)"; NSUnderlyingError = "Error Domain=NSOSStatusErrorDomain Code=-12348 \"(null)\""; }. 31/08/16 10:13:13.735 AM QuickLookSatellite[419]: [10:13:13.735] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:13.735 AM QuickLookSatellite[419]: [10:13:13.735] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:13.735 AM QuickLookSatellite[419]: [10:13:13.735] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:13.735 AM QuickLookSatellite[419]: [10:13:13.735] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:13.735 AM QuickLookSatellite[419]: [10:13:13.735] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/eou.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893 31/08/16 10:13:13.735 AM QuickLookSatellite[419]: [10:13:13.735] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/eou.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893 31/08/16 10:13:13.735 AM QuickLookSatellite[419]: [10:13:13.735] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157 31/08/16 10:13:13.735 AM QuickLookSatellite[419]: [10:13:13.735] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157 31/08/16 10:13:13.877 AM garcon[956]: Garcon destroyed (0 alive). 31/08/16 10:13:13.878 AM garcon[956]: host connection <NSXPCConnection: 0x7fc5196403d0> connection from pid 601 invalidated 31/08/16 10:13:14.236 AM Vectorworks[601]: [10:13:14.236] <<<< RemoteEncode - client >>>> vtRemoteEncoderWaitForPendingFramesToComplete: Encoder didn't emit all frames during Invalidate. cancelling them. 31/08/16 10:13:14.236 AM Vectorworks[601]: [10:13:14.236] vtCompressionSessionTrackFrameGetInfo signalled err=-12902 (kVTParameterErr) (Unrecognised VTVideoEncoderFrame token passed in by encoder) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/VideoToolbox/VTCompressionSession.c line 2301 31/08/16 10:13:15.252 AM mdworker[762]: [10:13:15.252] FigAtomStreamInitWithByteStreamWithSize signalled err=-12893 (kFigAtomStream_OffsetOutsideOfParent) (Offset exceeds stream length) at /Library/Caches/com.apple.xbs/Sources/CoreMedia_frameworks/CoreMedia-1731.15.206/Sources/Utilities/FigAtomStream.c line 305 31/08/16 10:13:15.253 AM mdworker[762]: [10:13:15.253] <<< FFR_Common >>> FigFormatReaderCreateForStreamReturningMatchingContainerLabelType: *** Could not create format reader for URL file:///Users/three/Desktop/eou.mov FileType '' MIMETYPE (null) SuggFileName (null) instantiationError = -12893 31/08/16 10:13:15.253 AM mdworker[762]: [10:13:15.253] FigFormatReaderCreateForStreamReturningMatchingContainerLabelType signalled err=-12893 (instantiationError) (Error creating FormatReader) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.206/Prototypes/FormatHandlers/FigFormatReader_Common.c line 2157
Edited by yomcatLink to comment
3 answers to this question
