ratherfishing Posted September 2, 2016 Share Posted September 2, 2016 Hi All I`m stuck with a problem. I`ve read threads about fixture rotation, but they seem not to give answers. So let`s say I have 4-lite Molefay fixture and I want to aim it towards audience. To rotate fixture, I have to edit 3D components of the symbol (If i try using 3d orientation, parts of fixture will explode all around). After editing components, my fixture looks right in 3D, but my symbol in TOP/PLAN-view looks the same as before editing components (it is the same if I rotate the fixture with 3d orientation). Then I go and delete 2d-components and paste 3d components. Now everything looks right, but when I try to use Instrument summary tool, it tells me "No 2D preview", since it obviously would need the 2D-components I have deleted. Sure I`m doing something wrong, so any help? Many Thanks. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 2, 2016 Vectorworks, Inc Employee Share Posted September 2, 2016 Instrument rotation when controlled via a Focus Point, which is generally easiest, is currently only applied to the 3D portion of a Lighting Instrument, but there have been many requests for rotation to show (as an option) in 2D. For the time being I think you have to manually edit the 2D component to appear rotated. But from what I recall, you shouldn't normally edit the 3D component and rotate that, the 3D component will follow the focus point by default. 1 Quote Link to comment
ratherfishing Posted September 2, 2016 Author Share Posted September 2, 2016 Thank you for your reply. Yes, if Focus Points are used, editing 3d Components is not necessary. Any help on how I can edit 2d component to appear rotated? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 2, 2016 Vectorworks, Inc Employee Share Posted September 2, 2016 I believe you would have to edit the 2D Component of the base symbol, which creates the problem of needing a duplicate of each lighting device symbol resource to represent each angle of rotation. If there is a cleaner way I am not aware of it, but this most likely explains why 2D rotation is so frequently requested. Quote Link to comment
markdd Posted September 3, 2016 Share Posted September 3, 2016 In the object info palette just set a rotation for the symbol. No editing required. In Spotlight preferences you can tell the symbols to rotate to their focus points automatically. Quote Link to comment
ratherfishing Posted September 3, 2016 Author Share Posted September 3, 2016 Hi, I attached a screenshot to show my problem. "By default" molefay will look the same, despite rotation values in object info palette. If I edit the symbol everything works ok until I want to insert Instrument summary tool. Thank you for your help so far. Quote Link to comment
markdd Posted September 3, 2016 Share Posted September 3, 2016 So you don't want to see the 2d portion at all? Quote Link to comment
ratherfishing Posted September 3, 2016 Author Share Posted September 3, 2016 Well, I quess I don`t. I want to see the fixture as it really looks like when viewed from top. And then the same for the instrument summary. Based on plots I`ve seen this is possible, but I have no idea how. Quote Link to comment
markdd Posted September 3, 2016 Share Posted September 3, 2016 (edited) In which case you will need to edit the 2d portion of the symbol to show what you need to see. There is no quick fix, so you will need to actually draft what you want to see in this instance. I often do this. Just duplicate the symbol, rename the symbol (the light info data will remain the same), edit the 2d portion and use it instead of the stock symbol. For symbols that are symmetrical front and back like floods and Molefays, then I often add an arrow to the 2D portion to make it clear which way it is pointing. I hope I understand you correctly. Mark Edited September 3, 2016 by markdd add more info Quote Link to comment
ratherfishing Posted September 3, 2016 Author Share Posted September 3, 2016 Hi, You understand just correctly, it was me who didn`t understand that I actually have to draft the 2d portion instead of rotating it or something. Now I know, thank you for your help and patience! Quote Link to comment
Guest Frank Brault Posted September 12, 2016 Share Posted September 12, 2016 It may be possible to eliminate the need to redraw portions of the lighting Device assigned symbol definition. In the currently shipping Vectorworks Spotlight, there is a checkbox in the File->Document Settings->Spotlight Preferences dialog: "Automatically Rotate 2D to Focus Point", which which overrides the user designated rotation value to agree with the Draw Beam angle. This rotates the 2D representation of all fixtures in the document to align with the assigned Focus Point object. Does this address your inquiry? Quote Link to comment
ratherfishing Posted September 27, 2016 Author Share Posted September 27, 2016 Hello Frank, sorry for missing your post earlier. I`m sure it would work with many symbols, but not with molefays for example, since the symbol itself looks "wrong" by default. I`m afraid I have a new question and I think it is close enought to be asked in the same thread: Now, once I have gotten to a point where my symbols look right in the 3d, 2d and in the instrument summary, what would be the best way to have colors in the symbols shown in instrument summary? I use layer colors with different fixtures, but colors are not shown in the instrument summary. Thank you again. Quote Link to comment
