ericjhberg Posted August 25, 2016 Share Posted August 25, 2016 I wrote a script for a simple rail fence. The rails are created using the path extrude node, substituting in different fence rail profile symbols for the profile. The path is nothing more than a 2D poly The problem I am having is that I cannot seem to figure out how to get the z height of the path extrude to respond to any nodes. I have tried the Set Height and Set 3D Info nodes to no avail. I have also tried to just query the Z height using the Get 3D Info node and the results never come out correct. Any ideas? Quote Link to comment
Kevin McAllister Posted August 25, 2016 Share Posted August 25, 2016 (edited) Take a look at Alan's fence experiment - https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=231726#Post231726 He uses the Move node to position his rails. See attached image. Kevin Edited August 25, 2016 by Kevin McAllister Quote Link to comment
