mgt Posted July 21, 2003 Share Posted July 21, 2003 i'm hoping there is a simple command somewhere to turn this thing off, but... we have a curved wall on one of our drawings - and the radius is shown in red. This is fine with the exception that no one knows how the radius line got there, or how to turn it off. We can't select it, move it or edit it in any way. It isn't a huge issue because it doesn't show up when we print the sheet- but it is a bit annoying when one is trying to work on the drawing. does anyone know about this? -mgt Quote Link to comment
jfmarch Posted July 21, 2003 Share Posted July 21, 2003 i may be wrong, but it sounds like the wall has a parametric constraint attached to it (from the palette of the same name). i don't use those things that much so i would think you could select it and delete it. have you tried to duplicate the wall and see if it is still attached to the new wall, or deleted the wall and redraw it in the same place? hope this helps. Quote Link to comment
mgt Posted July 21, 2003 Author Share Posted July 21, 2003 ah... Deleting parametric constraints select the object- in the menu bar Edit--->Edit Constraints delete the constraint... Quote Link to comment
Guest Posted July 22, 2003 Share Posted July 22, 2003 Usually when smething is in red and you can't select it AND it doesn't print- that's a parametric constraint. Quote Link to comment
